Shift linkage seal on 97 civic dx y7. - Honda-Tech
Old 03-19-2017, 08:58 AM   #1
Default Shift linkage seal on 97 civic dx y7.
I recently replaced the shift linkage seal on the shift input shaft on my tranny and after about a month i got under there to change the oil and noticed it was leaking again. I got the new seal from honda and installed it correctly. Any one know why it would still be leaking?? Is it suppost to let a little by? Or time for new shift linkage?? Thanks in advance for the help!!
Flakie is offline   Reply With Quote
Old 03-21-2017, 08:53 AM   #2
Default Re: Shift linkage seal on 97 civic dx y7.
Bump help please
Old 03-21-2017, 01:02 PM   #3
You may have damaged the new seal during installation. For example if the shaft is rough where the pin goes through. Did you do it from outside with transmission on the car or did you take the transmission apart so you can pull the shaft out of the inside? I think the latter method is recommended.
mk378 is offline   Reply With Quote
Old 03-21-2017, 03:55 PM   #4
No i did it with the transmission on the car. I didnt even think to check the shaft for ruff spots before i installed it. I can always purchase another one and replace it and see if it does it again. There fairly in expensive and its not hard to do. I used a 15mm socket to install it and tap it in lightly. The seal didnt leak for a good month or so. I checked it 2 weeks on a row after install and it was not leaking. If there is burs on the shaft do i just get fine sand paper and smooth it out?
Oil leakage from shifter shaft..... bandit67 Honda Civic / Del Sol (1992 - 2000) 7 04-01-2015 04:45 AM
leaking from shift linkage on gsr tranny eg6206 Transmission & Drivetrain 10 03-04-2012 11:03 AM
WTB b seres shift linkage 90datech Mid-Atlantic (Sales) 3 05-06-2011 02:29 PM
Wtb shift linkage Jdmbsixteen For Sale 4 09-03-2003 12:56 PM
shift linkage See Are X Honda CRX / EF Civic (1988 - 1991) 16 09-01-2003 12:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
