need help burning oil
Re: need help burning oil
Have someone follow while you drive and ask them to look for dark blueish smoke from exhaust when you fast accelerate and decelerate.
Read this: https://www.amsoil.com/techservicesb...onsumption.pdf
Did you thoroughly clean the engine, cover with baby powder and inspect for leaks?
Using conventional or synthetic oil?
Last time PCV valve inspected/replaced?
This doesn't specify how much has burned off in a month or even the distance travelled for the burn off.
Honda spec states the car can burn up to 1 liter of oil every 1500 kilometers before it's considered a problem.
It sounds to me like a proper break in procedure was not done upon rebuild. The car was likely babied too much immediately after rebuild when it should have been put through it's paces.
Pulled from motoman (my favored method):
Step 1 | Do three cycles | Redline 6500 | Redline 7200 | Redline 8400 |
1st | 40% RPM to 60% RPM at half throttle | 2600 RPM - 3900 RPM | 2880 RPM - 4320 RPM | 3360 RPM - 5040 RPM |
cycle | 60% RPM back to 40% RPM at zero throttle (Do not use the brake!) | 3900 RPM - 2600 RPM | 4320 RPM - 2880 RPM | 5040 RPM - 3360 RPM |
2nd | 40% RPM to 60% RPM at half throttle | 2600 RPM - 3900 RPM | 2880 RPM - 4320 RPM | 3360 RPM - 5040 RPM |
3rd | 40% RPM to 60% RPM at half throttle | 2600 RPM - 3900 RPM | 2880 RPM - 4320 RPM | 3360 RPM - 5040 RPM |
If done on dyno, allow 15 minutes to cool engine before doing step 2 | ||||
Step 2 | Do three cycles | |||
1st | 40% RPM to 80% RPM at 3/4 throttle | 2600 RPM - 5200 RPM | 2880 RPM - 5760 RPM | 3360 RPM - 6720 RPM |
cycle | 80% RPM to 40% RPM at zero throttle (Do not use the brake!) | 5200 RPM - 2600 RPM | 5760 RPM - 2880 RPM | 6720 RPM - 3360 RPM |
2nd | 40% RPM to 80% RPM at 3/4 throttle | 2600 RPM - 5200 RPM | 2880 RPM - 5760 RPM | 3360 RPM - 6720 RPM |
3rd | 40% RPM to 80% RPM at 3/4 throttle | 2600 RPM - 5200 RPM | 2880 RPM - 5760 RPM | 3360 RPM - 6720 RPM |
If done on dyno, allow 15 minutes to cool engine before doing step 3 | ||||
Step 3 | Do three cycles | |||
1st | 30% RPM to 100% RPM at full throttle | 1950 RPM - 6500 RPM | 2160 RPM - 7200 RPM | 2520 RPM - 8400 RPM |
cycle | 100% RPM to 30% RPM at zero throttle (Do not use the brake!) | 6500 RPM - 1950 RPM | 7200 RPM - 2160 RPM | 8400 RPM - 2520 RPM |
2nd | 30% RPM to 100% RPM at full throttle | 1950 RPM - 6500 RPM | 2160 RPM - 7200 RPM | 2520 RPM - 8400 RPM |
3rd | 30% RPM to 100% RPM at full throttle | 1950 RPM - 6500 RPM | 2160 RPM - 7200 RPM | 2520 RPM - 8400 RPM |
If done on dyno, allow 15 minutes to cool engine before doing any more pulls |
Is the motor running properly currently? Any knocking or abnormal noises? From my experience with a 2007 Mazda 3 (2,3L) engine which suffered from excessive oil consumption the internals (bearings, crankshaft) tolerances opened past spec and soon after developed rod knock. When I searched online it seems to be an occasional problem with the Ford Duratec 2.3L engine that that generation of Mazda 3's used. The engine had 192k miles on it when it died so I certainly can't say it's a bad engine. This may or may not be the situation with your engine however, if it wasn't rebuilt correctly and spec tolerances weren't adhered to it very well may be the issue. What is the lowest level on the dipstick the oil got down to?
If you are absolutely certain it's burning and not leaking oil (4 quarts in a month) your options are pretty limited and my guess is it won't be long before another rebuild or replacement is in order. First thing is drain oil and inspect the oil for metal particles..if you find metal particles then most likely from worn main bearings. If you don't see metal in oil then to slow burning go up to a thicker viscosity : 40w (weight) oil. You can try Lucas oil stabilizer or similar product. Also, if it's burning that much oil it may clog up the catalytic converter (if not clogged already) If you live in a state that doesn't do inspections you may want to gut the cat (knock screens out) but, it's against federal law regardless of state so, do at your own risk.
I'm currently burning more oil than i should be but its completely obvious as you cant smell anything but oil if your within 20ft of the car while its idling.
i just did a oil change and put exactly 3.75 quarts in so i can monitor how fast its burning. and im pulling my plugs this evening to see if they show signs of anything.
like jimi said have someone follow you because i haven't specifically noticed smoke until last evening when i really hit the throttle but i only noticed it because there was a car still sitting in the same spot behind me and his headlights lit the small cloud up.
again very very hard to notice through your rear view.
r.etheridge
21
02-11-2011 07:33 PM
