Shaking at first gear
Old 09-01-2015, 02:15 PM
Nick Kozeski's Avatar
Default Shaking at first gear
Good evening honda tech. My 96 civic cx has a problem when I'm in first gear and slowly letting go of the clutch and accelerating, the car starts to shake and it feels sluggish to when it goes but 2nd 3rd 4th and 5th are fine it's just 1st. Remind you that I just put in a new clutch and transmission. Can someone have any idea why it's causing it to lose power then slowly move the car. I was thinking it can be the wires, distributior, and plugs but before I change those parts has anyone experienced this issue?
Old 09-01-2015, 02:20 PM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
Default Re: Shaking at first gear
Well...if we're ruling out driving technique, clutch adjustment (as related to driving technique), and other factors like having the AC on...
Shaking:
-you have hotspots on your flywheel because you didn't resurface it.
-you have oil or grease on the flywheel or pressure plate surface.
Loss of power:
-you turned the motor clockwise while trying to loosen/tighten some bolts and jumped a tooth on the timing belt.
Old 09-01-2015, 02:31 PM
White_EG1's Avatar
Motor mounts
Old 09-01-2015, 06:08 PM
theYBLEGAL's Avatar
New transmission... 99% of time you mean used..
Did you check input shaft play? ***** old now, most input shaft bearings are toast and need replaced.
Old 09-03-2015, 03:37 PM
Just did a tune up on it. It stopped the shaking but still no torque in first gear and yes it's a used tranny I checked shaft it is fine
Old 09-03-2015, 03:57 PM
I never narc'd on nobody!
NotARaCist's Avatar
<p>Ignition/mechanical timing. &nbsp;Check it.</p>
Old 09-04-2015, 07:14 AM
B serious's Avatar
But....my suggestions......
Old 09-04-2015, 02:52 PM
I believe it is the timing because when I put the new clutch in it started to turn while I was torquing it
Old 09-04-2015, 04:06 PM
theYBLEGAL's Avatar
It doesn't matter if the crank/flywheel moves. As long as you didn't unbolt the distributor, timing should be unaffected
Old 09-04-2015, 04:09 PM
Technical Hero
HondaPartsHero's Avatar
What type (brand) of clutch did you put in?
Old 09-04-2015, 06:14 PM
B serious's Avatar
Cam timing. If the motor is rotated backwards with either an old belt or old tensioner/spring, it can skip timing.
Old 09-04-2015, 07:07 PM
theYBLEGAL's Avatar
I will buy that. But, I would also consider that a less likely possibility. But thats me. None the less, it should be checked.
Old 09-04-2015, 07:41 PM
NotARaCist's Avatar
<p>There's a reason the FSM specifically states that the motor should only ever be turned one direction.</p>
Old 09-04-2015, 11:54 PM
B serious's Avatar
Its actually a more common phenomenon than you'd think. Happens on chain cars as well.
Old 09-05-2015, 07:23 AM
I bought a durlast clutch from auto zone nothing crazy I just wanted it to fit my car and I didn't take off the distributor but maybe the last owner did and messed up the timing
Old 09-05-2015, 07:24 AM
I'm not really sure how to check timing on single cams I did timing on a double cam before but idk if it's that same with single cams
Old 09-05-2015, 08:58 AM
theYBLEGAL's Avatar
Same scenerio as b series, point cam to tdc and crank, make sure belt didn't skip teeth. Then use a timing light to sync the marks on the crank pully with the timing mark/notch on the timing case
Old 09-05-2015, 08:12 PM
Ok will do thanx
Old 09-06-2015, 11:54 AM
B serious's Avatar
Eh...you may not be able to adjust that duralast clutch properly. For future reference, an exedy B series oe replacement is like $120 on rockauto or ebay.
Old 09-06-2015, 12:52 PM
Technical Hero
I'm going to go out on a limb and say the clutch is bad. I've never had good luck with over the counter store brand clutches. Like stated above stick with Exedy and either have your flywheel resurfaced or replace it.
Old 09-06-2015, 06:32 PM
Thanx for the advice guys I'm probably going to get a new clutch and check the timing at the same time
eg6 type-R
04-09-2012 06:19 AM
vtec128
11-08-2010 06:16 AM
usdmEHboy
Transmission & Drivetrain
06-05-2010 10:11 AM
BB6matik
05-23-2010 10:38 PM
wolve
04-29-2009 07:40 PM
Quick Reply: Shaking at first gear
