shakes like hell!!!!
Old 01-10-2007, 06:20 AM
19992civichatch's Avatar
Default shakes like hell!!!!
when i hit the brakes my car shakes like its, its job what the hell is it?
Old 01-10-2007, 06:24 AM
B18CivicEH2's Avatar
Default Re: shakes like hell!!!! (19992civichatch)
maybe the bearings....or maybe your pads went out and now you're rubbing metal to metal...OUCH
Old 01-10-2007, 06:27 AM
brand new brakes and whe ni mean brand new lie k2 weeks a go could it be the motor mounts casue there kinda shot in my car but i dont no if that would casue that?
Old 01-10-2007, 06:28 AM
Default Re: (19992civichatch)
yea man, prob bad bearings...if your mount got messed up, replace it please, that can lead to future probs...
Old 01-10-2007, 06:34 AM
lsjon's Avatar
im leaning more towards your rotors being bad, even if u have new pads, if you or whoever didnt resurface the rotors then the pads wouldnt sit right and u will see problems such as vibration, also if your rear brakes were adjusted to tight u will also see vibrations.
Old 01-10-2007, 06:39 AM
guttedEF's Avatar
If it's a hard pulsation type shake, then it's probably the brakes. Like he said, if you didn't replace or resurface the rotors, then that could definetely be the issue.
if it were the motor mount it would probably be just one big clunk, not a continuing vibration when stopping.
Old 01-10-2007, 07:28 AM
cibola's Avatar
Default Re: (guttedEF)
Sounds like your rotors are warpped. Get them resurfaced at a machine shop and that will make them flat again.
You should replace or resurface your rotors everytime you replace the pads.
Old 01-10-2007, 10:37 AM
jjspec's Avatar
Default Re: (cibola)
Also torque your nuts at 80 ft/lbs to prevent in the future.
Old 01-10-2007, 02:10 PM
hard charging 929's Avatar
Default Re: (jjspec)
As stated above, hit the brakes and car shakes, you have rotor problems. New pads or not. If you have one or know someone who has a brake micrometer then mic them for their measurement and compare to the service limit. If they can be resurfaced, get er done. If not then replacements aren't that much of strain on the wallet.
Old 01-10-2007, 02:12 PM
bart2546's Avatar
Default Re: (agoldenau)
rotors for sure
Old 01-10-2007, 02:21 PM
StolenTeg's Avatar
Default Re: (bart2546)
New rotor for civic are like 30 buck for both
Old 01-10-2007, 10:42 PM
guttedEF's Avatar
I myself wouldn't resurface a warped rotor.. it won't stay flat long.. Like he said, just replace theme very times, for the price there's no reason not to.
Misfit2613
Suspension & Brakes
13
05-29-2015 05:20 PM
R81_DC2
03-30-2007 10:23 AM
Hatchd
04-03-2006 10:40 AM
IMMORTAL-B18
07-19-2004 12:37 PM
BlackOut21
01-07-2003 10:37 AM
Quick Reply: shakes like hell!!!!
