secondary o2 sensor location on 98 civic EX?
Old 05-26-2011, 01:31 PM
blacktibby07's Avatar
Default secondary o2 sensor location on 98 civic EX?
i cannot seem to find where the wiring goes or starts....
my car originally 98 civic lx 1.6l y7 non vtec....
now i have EX head and ECU, with Harness and cant find where secondary plug is at on harness? someone take a pic plz?
i do have 2 sensors under intake manifold that dont go anywhere, i know one is for knock sensor which i bypassed and the other sensor looks exactly like the o2 sensor on primary but instead of III it looks like I-I-I ....
the dashes inbetween the I's representing solid area and wont hook up
blacktibby07 is offline
Old 05-26-2011, 01:52 PM
Former User's Avatar
Default Re: secondary o2 sensor location on 98 civic EX?
The secondary O2 sensor connector drops through a hole in the body above the catalytic converter.
Former User is offline
Old 05-26-2011, 02:13 PM
cheggie's Avatar
Here's a picture, with the converter removed. I took a picture of the trans tunnel, and realized I caught the hole where the secondary o2 sensor comes out. There was a blue rubberized plug that seals the connector to the hole in the floorpan. Pull it down a few inches, and the connector will hang out just enough to unplug it, like you see in the picture.
cheggie is offline
Old 05-26-2011, 05:02 PM
Technical Hero
HondaPartsHero's Avatar
You'll have to extend your secondary O2 to meet the new location on the catalytic converter
HondaPartsHero is offline
Old 05-26-2011, 05:20 PM
I have the chasis of a 98 civic lx, that's not on my car, the lx harness that I had had the secondary next to the primary on the ex harness I now have I can't find the the connector
Old 05-26-2011, 05:35 PM
sdobson910's Avatar
The ex harness locates the secondary plug inside the cabin near the shifter. You'll have to manually wire in the second O2 sensor.
sdobson910 is offline
Old 05-26-2011, 05:53 PM
Ok so its on the cabin harness not the harness that goes under the hood? Where do I splice? Got a diagram for the pin slots on ecu?
Old 05-26-2011, 06:42 PM
apexi_rsx's Avatar
what harness are u running on the car? u shouldn't need to do any splicing its either there or its not? if not and u have a dx harness u need to just cut the wireloom open some and extend the wires to the back. if u bought a ex engine harness and have a dx car ur better off finding a dx harness and just wiring vtec. o2 sensors have shielded wires and u would have to use one if u do this.
apexi_rsx is offline
Old 05-26-2011, 06:54 PM
I have a ex wire harness the one that runs thru fire wall and into engine bay, now what part of harness is the secondary plug?
Old 05-26-2011, 08:16 PM
It's part of the floor harness.
Old 05-27-2011, 01:35 AM
Technical Hero
http://ff-squad.com/wp/?p=395
Old 05-27-2011, 06:03 AM
So I have to manually wire? No Aftermarket hookup I can buy? If I do have to manually do it, what gauge wire do I need and about how much length?
Old 05-27-2011, 02:48 PM
hey i still have my y7 harness, can i just take the secondary o2 sensor wire setup, unwrap the harness to get it loose, depin it from the connector then pin it back into y8 ecu?
Old 09-28-2011, 10:09 PM
Player_One's Avatar
Awesome! I needed that pic. :D Now, my question is, how large is that hole? I have a hole in approximately the same place in my 93 Del Sol (that was before Honda added a secondary O2 sensor). I just need to know if I have to drill that hole bigger to drop the connector through.
Car is K-swapped so my connectors may be too big for the default sized hole. And that's where my primary O2 sensor is located (not secondary).
Player_One is offline
Old 05-20-2015, 03:33 PM
swizz977's Avatar
is that hole on the dx chasis i need to run my o2 wire eather under the car or thru the firewall and out that hole
swizz977 is offline
Old 05-20-2015, 04:53 PM
Create your own thread where you post pictures of said hole location, and also provide car information (year) and some background.
itsrooster
15
08-24-2013 04:15 PM
sol_1
05-21-2009 12:34 PM
kelviiv
07-09-2008 10:53 PM
ozir
11-19-2005 05:11 PM
Quick Reply: secondary o2 sensor location on 98 civic EX?
