so i got a b20z.....
Old 10-19-2005, 01:15 PM
blazeone44's Avatar
Default so i got a b20z.....
i recently got a b20z bottom end with a gsr head, basic bolt ons (intake, headers, intake manifold, and koyo radiator. i had wanted to run hondata s100 but i was told that my block could not handle this without sleeves.....is this true??
Old 10-19-2005, 01:21 PM
SpoOoLin EK's Avatar
Default Re: so i got a b20z..... (blazeone44)
unless ur going forced induction i dont see why tuning your b20vtec would be bad...i call bullshit...
Old 10-19-2005, 01:28 PM
CALIdelsolSIR's Avatar
Default Re: so i got a b20z..... (SpoOoLin EK)
i agree. b/s.
Old 10-19-2005, 01:31 PM
ralphie14's Avatar
Default Re: so i got a b20z..... (CALIdelsolSIR)
yeah the only thing that would comprimise the the block would be forced induction. If the motor runs now I would think that with adding Hondata and tuning it will not do anything but make it better/safer as long as it is done right.
Old 10-19-2005, 01:32 PM
ek2k's Avatar
the only reason why people run sleeved b20's is if they are doing forced induction and are pushing more tha 7psi and even 7 is alot already for a stock b20. Since you have a b20Z you are better of than most because the b20z has better pistons which create a higher compression and the 99- b20z is made a little more stronger than the prior ones. I had a b20 vtec check my sig..and it hauled *** it was semi built and ran like a champ...hope that helps...
Old 10-19-2005, 03:35 PM
blazeone44's Avatar
bump
91CIVICHATCHH22
11-05-2010 11:26 PM
2.0L_of_fun
15
03-02-2010 08:54 AM
chb93
08-02-2009 06:00 PM
hwt101
12-07-2008 02:06 PM
highmilehatch
04-08-2002 02:20 PM
Quick Reply: so i got a b20z.....
