Running hot at idle
Update: Running hot at idle
I just bleed the system, I ran it for like 20-25 mins, the temp stayed 1/2 way up the whole time, but towards the end it started to bubble coolant out of the neck, so I shut it off. The fan did kick on pretty late in the process. I then checked the coolant level and had to add quite a bit to get it back up.
Question is it normal to bubble out coolant?
[/I]COLOR]I have a 96 civic, when I drive for say half hour and park it and let it sit running, the temp guage will go to about 3/4 up (not into red) and then finally the fan will kick on and start to cool down.
Seems like the fan is coming late.
I know the fan is working because I can hear after I turn the key to position 2 and hear it.
I am wondering can it be the thermo switch on the thermo housing? but is that is the case would it just fail and not work at all?
Is there a way to test the switch with an ohm meter?
Any ideas?
Any ideas?
Re: Running hot at idle
Start by topping off coolant in the cooling system and then bleeding the system.
Bleeding the cooling system may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push/turn the dash heater lever/**** to MAX heat. Fan need not be on.
3) Follow the directions in the diagram below
I did have a new radiator put in a few months ago and he flushed the system, I saw him use a special funnel and let run for like a long time and coolant was slowly going in, I assume he tried to get all the air out, but maybe some is still in there?
Jamie Steadman
08-14-2015 12:07 PM
hotdoggies
17
07-11-2011 06:18 PM
