Rocker arm adjustment. - Honda-Tech
Old 12-18-2008, 09:28 PM   #1
VTEC1n2nd's Avatar
Default Rocker arm adjustment.
SO my rocker arms make a ton of noise on my d16y8 when i get around 3k RPM. It gets annoying after a while. Is there any way to adjust them?
VTEC1n2nd is offline   Reply With Quote
Old 12-18-2008, 10:27 PM   #2
Jimster480's Avatar
mine just whine. But then again my motor is just beat. Which is why im swapping it out of there lol.
Jimster480 is offline   Reply With Quote
Old 12-18-2008, 10:42 PM   #3
Ruben19's Avatar
this is call a valve adjustment job.
Ruben19 is offline   Reply With Quote
Old 12-19-2008, 06:39 AM   #4
Jimster480's Avatar
Quote:
mine needs more than that.
Old 12-19-2008, 06:55 AM   #5
z6hatchboy's Avatar
for the op, to do a valve lash adlustment. Take the v/c off and at the end of the rocker arm will be a lock nut and lash adjuster that goes does to the valve. Loosen the lock nut with a 8 or 10mm wrench, use a feeler gauge between the valve and adjuster and adjust the aduster to spec. I think the inake is .008" and the exhaust is .012"..i tihnk but go look your up and make sure
z6hatchboy is offline   Reply With Quote
Adjustable rocker arms CR3X Tech / Misc 1 10-08-2008 07:44 AM
Valve tick... VtecAdvantage Honda Motorcycles 0 12-16-2006 07:25 AM
Rocker arm adjustment ? 95 Quelude SI Honda Prelude 5 11-01-2006 03:45 PM
suspension question Jcards26 Suspension & Brakes 2 04-25-2005 12:56 PM
vavle adjustment quest. Bongnak Honda CRX / EF Civic (1988 - 1991) 2 10-06-2002 08:30 PM
Tags
2000, 94, accord, adjustment, arm, civic, del, honda, odyssey, rocker, rockerm, sol
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
