reseting ecu......
Old 08-16-2001, 10:28 AM
00fbp's Avatar
Default reseting ecu......
I recently got an intake and someone told me that it is a good idea to reset the ecu. I was wondering how to reset the ecu?? thanx for all your answers.
Old 08-16-2001, 10:37 AM
maxim's Avatar
Default Re: reseting ecu...... (00fbp)
Disconnect the negative terminal on the battery....yes, it's that easy.
Old 08-16-2001, 11:27 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: reseting ecu...... (maxim_force)
Pull the ECU fuse for 10 secs. Or pull the NEG of the batt for 10 secs.
Old 08-16-2001, 12:15 PM
sohc_boy's Avatar
Default Re: reseting ecu...... (B18C-EJ1)
actually i thought it was 2 fuses the ecu and backup
Old 08-16-2001, 12:37 PM
3.3.3's Avatar
Default Re: reseting ecu...... (sohc_boy)
remember, if you have an alarm, itll go off when you disconnect the -terminal. it will also reset everything in the car (e.g. clock, all your important music stations) just pull tha fuse for about 30 secs and then restart car. let the car idle for about 5 minutes, then shut her off. restart again, and drive it like its hot.
Old 08-16-2001, 08:18 PM
93LSivic's Avatar
This does absolutely nothin. It is a common Honda myth. I figured I would clue you in. Honda ECU's learn as they go along. Now, what this will do is reset your ECU if it has thrown a code, that is the only reason why you would ever have to do that.
Slo_Accord
11-10-2007 12:47 AM
Fatty_1775
08-05-2003 05:37 AM
cp_harrington
01-20-2003 08:35 PM
illusion
02-18-2002 03:02 PM
Quick Reply: reseting ecu......
