Replacing intake manifold gasket... - Honda-Tech
Old 06-01-2009, 07:13 AM   #1
EX-T's Avatar
Default Replacing intake manifold gasket...
So my OEM gasket has blown out and my car is idling at like 1500 rpm.
Are there any tricks or tips to installing a new gasket? Do I need any hondabond or anything?
BTW, it's a '99 EX and I'm putting a Hondata gasket on it.
EX-T is offline   Reply With Quote
Old 06-02-2009, 07:07 AM   #2
EX-T's Avatar
Default Re: Replacing intake manifold gasket...
Sweet! No one has put an intake manifold gasket on before! w00t!!
Old 06-02-2009, 07:14 AM   #3
ballisticej1's Avatar
Just pull off the intake mani, throw on some hondabond or some other type of gasket sealing stuff if you want, not too much though, and put it back on, pretty straight forward.
ballisticej1 is offline   Reply With Quote
Old 06-02-2009, 07:16 AM   #4
EX-T's Avatar
So, I do need some hondabond?
Old 06-02-2009, 07:26 AM   #5
Quote:
You don't need but it would help to seal it up tighter.
Old 06-02-2009, 07:28 AM   #6
EX-T's Avatar
word
Old 07-20-2009, 01:03 AM   #7
fc3srx729's Avatar
Install the gasket dry...
fc3srx729 is offline   Reply With Quote
Old 07-20-2009, 02:40 AM   #8
Jackal6042's Avatar
Quote:
X2 OE Honda gaskets have a rubber seal around the water jacket that works just fine.
OP, why did you decide to go with the HonData gasket? How much did that **** set you back?
Jackal6042 is offline   Reply With Quote
Old 07-20-2009, 02:57 AM   #9
NACvicSi's Avatar
Hondata gasket = waste of money
OEM or GTFO
NACvicSi is offline   Reply With Quote
Old 07-20-2009, 07:53 PM   #10
Jackal6042's Avatar
Quote:
OEM or GTFO
LOL, agreed. All I ever use for IM gaskets etc is OEM. How much do HonData gaskets go for anyway? Probably much more than its worth.
OEM Honda IM gasket for you 99 EX is part number 17105-P2P-A01, probably can get it for like $19-$23 from the dealer.
Old 05-04-2014, 09:02 PM   #11
I know... old thread. Just curious if anyone has used the myhondahabit intake manifold gasket. I have the stud kit, but am ready to swap out my hondata gasket for something that won't bulge into the runners. They claim their is a thermal gasket too, but not made of plastic.
typerwhat is offline   Reply With Quote
Vtec solenoid gasket Lightsped Honda Civic / Del Sol (1992 - 2000) 12 05-27-2009 03:20 PM
OEM Oil Cooler Leak, Cooler or Gasket? Nisif Honda Prelude 2 10-06-2008 09:32 PM
Cheap fix for head gasket... lax1089 Honda Accord (1990 - 2002) 22 05-24-2007 11:35 PM
Help with ZC head gasket problem ZippyZivic Forced Induction 15 10-12-2006 05:27 AM
Leaking cylinder head gasket on my 96 EX Civic mainstreet All Motor / Naturally Aspirated 0 07-15-2006 11:06 AM
Tags
1990, blown, civic, diy, gasket, gaskets, honda, hondabond, hondata, intake, manifold, oem, prelude, replace, replacing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
