Replacing the Ignition Switch (1994 Honda Civic EX) - Honda-Tech
Old 05-28-2009, 07:42 AM   #1
New User
Default Replacing the Ignition Switch (1994 Honda Civic EX)
Yesterday, through the help of many of you (thank you!), I think I figured out that my ignition switch needs to be replaced on my 1994 Honda Civic EX with 171k (see below). I called Honda Parts this morning and the sales person told me the ignition switch with new keys is $335 (Part # 35100SR3A13). From something I read yesterday, I didn't think the lock cylinder had to be replaced. Does it?
I found a local independent mechanic who will try to find the part at a junk yard for around $75-$100 and install it for $65. Is this advisable?
I started having problems immediately after I took my car for state and emissions inspection. During the inspection, I waited nearby as the mechanic tested my car and it sounded like he put the car under tremendous strain to do the emissions test. Could the test have caused my problem? If so, do you think I have any recourse?
Summary of Problem: Even while being jumped, my car with the ignition switch in ON (II) does not have any dashboard lights but the radio operates and "door open" sound works. If turn it to START (III) while being jumped, it sounds like it has started and I have dashboard lights, but as soon as I release the key, the car dies and the lights go out.
Thanks again for your help!
Lisa
Please Help! is offline   Reply With Quote
Old 05-28-2009, 08:02 AM   #2
Default Re: Replacing the Ignition Switch (1994 Honda Civic EX)
The diagrams below show how to test and replace the ignition switch. Unfortunately, you do need to replace the whole lock cylinder.
You should be able to get a discounted price for an OEM lock cylinder here.
Former User is offline   Reply With Quote
Old 05-28-2009, 08:13 AM   #3
civic_driver's Avatar
I've heard that you can replace the lock cylinder and reuse the key but it requires some work and a mechanic might not want to do it.
civic_driver is offline   Reply With Quote
94 Accord ; are these symptoms PCM, MAP, or other ? Budster Honda Accord (1990 - 2002) 5 05-31-2016 08:26 PM
1993 Honda Accord Ignition Switch Problems clifftbrd Honda Accord (1990 - 2002) 1 04-26-2014 11:50 AM
Dashboard Indicator Lights -- What's Normal? 2013Civic Honda Civic (2006 - 2015) 0 12-24-2013 10:30 PM
new starter now my car wont start booted_wishes09 Honda Accord (1990 - 2002) 16 05-20-2011 12:22 AM
Acura Legend Ignition Switch EricUSC Tech / Misc 4 11-01-2003 10:38 PM
Tags
1994, 94, accord, change, civic, cylinder, diagram, honda, igintion, ignition, ignitor, lock, replace, replacing, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
