Replacing A/C thermostat without removing evaporator
Old 07-23-2013, 10:35 PM
vinuneuro's Avatar
Default Replacing A/C thermostat without removing evaporator
How is the A/C thermostat mounted in the evaporator in an EJ,EK,EM? Is it possible to replace (reintall) it without pulling the evaporator?
Old 09-10-2013, 05:56 PM
jeremyhughes's Avatar
Default Re: Replacing A/C thermostat without removing evaporator
I know in the 1992-2001 the thermistor that is connected to the thermostat is ran into and clasped to the foils on the inside of the casing, but you cant remove it without opening up the casing, you can open the casing without removing it entirely first.... whhhich means having the system discharged and then recharged.
JimRaynor90
08-13-2014 07:23 PM
jdm-ek-si
03-31-2009 04:15 PM
05em2
06-22-2005 11:02 PM
Quick Reply: Replacing A/C thermostat without removing evaporator
