Replaced ECT but still get check engine light
Old 06-01-2014, 08:10 AM
Timbo66's Avatar
Default Replaced ECT but still get check engine light
I just completed an engine swap on a 1998 Civic 1.6L Vtec. Now I get a CEL and a P0117 OBD code ("ECT Circuit Malfunction - Engine Coolant Temperature Circuit Low Input") which causes it to idle badly and it does not start well, especially when cold.
I replaced the ECT sensor and reset the CEL but it comes right back.
Measuring the impedance across the ECT sensor after a short drive it shows around 350 Ohms, which is a reasonable value for a warm engine according to my research.
I am pretty sure I have not mixed up the ECT and the radiator fan connectors as sometimes happens, because the fan connector is on the thermostat and when I short those pins the fan comes on.
I measured the voltage coming from the ECT connector (which presumably goes to the PCM?) I see ground on one pin and 12V on the other. The odd thing is I have found various statements one the internet saying the reference voltage should be 5V however I see 12V coming from the PCM.
I could use some help with next steps. Thanks.
Old 06-01-2014, 05:06 PM
Fish Twig
tony_2018's Avatar
Default Re: Replaced ECT but still get check engine light
What all was replaced during the swap?
Old 06-01-2014, 07:43 PM
Timbo66's Avatar
Long block - block, head, and all internals. Everything else was moved from the old engine.
Old 06-01-2014, 08:24 PM
nub
nub's Avatar
350 ohms would be around 190-200 degrees so I wouldn't consider that "warm" after a "short" drive.
Input voltage to the ecu varies with temperature from .1V-5V
To make sure you have the correct plug the wire colors for the ECT on a 98 Civic are grn/blk and red/wht
Old 06-02-2014, 05:10 PM
Timbo66's Avatar
BINGO! I had the ECT plug reversed with another plug just below the Vtec solenoid. Duh. Thanks for the help!
street_ride14
03-14-2015 10:48 AM
myefhasaname
03-17-2013 10:37 PM
CantGetRich
10-07-2004 08:48 AM
pennies_hatchie
10-31-2002 09:58 AM
erniecars
05-09-2002 06:17 PM
Quick Reply: Replaced ECT but still get check engine light
