transmission issue? help please
Old 03-06-2011, 05:26 PM
f22vtec1's Avatar
Default transmission issue? help please
my ls transmission makes a loud rattle noise at idle as well as it makes a wierder noise when i drive 2 different noises... but other then that it shifts fine any ideas?
before i got it the guy said he changed the clutch & throwout & pilot bearings but he said it always made this noise since he got it
Old 03-06-2011, 06:19 PM
f22vtec1's Avatar
Default Re: transmission issue? help please
bump someone any advise?
Old 03-06-2011, 07:22 PM
Former User's Avatar
Does the noise go away when the clutch pedal is pushed down?
Old 03-06-2011, 07:39 PM
f22vtec1's Avatar
yes it does... but the noise while driving wont go away till i come to a complete stop
Old 03-06-2011, 07:52 PM
Your problem is likely a bad transmission main bearing, typically the input shaft bearing.
Old 03-06-2011, 08:02 PM
f22vtec1's Avatar
so junk it ? is that something easy to fix or pricey?
Old 03-06-2011, 08:06 PM
There is a DIY in the FAQs sticky. Or you could replace the transmission.
Old 03-06-2011, 08:13 PM
f22vtec1's Avatar
k thank you
Old 03-07-2011, 01:49 PM
f22vtec1's Avatar
curious was looking at rebuild kits can i use a rebuild kit from a ys1 or a gsr tranny to rebuild my ls tranny? would all parts interchange with eachother?
Old 03-08-2011, 12:05 PM
f22vtec1's Avatar
bump
phelpsj2
01-04-2010 02:27 PM
mayfly
12
08-04-2009 04:09 PM
diamondstarsforever
06-15-2009 09:50 AM
Ge-money
09-12-2006 06:23 AM
4gnhatch
06-24-2005 06:53 PM
Quick Reply: transmission issue? help please
