Removing Rear Interior/Trunk Panels on 98 EK Hatch? - Honda-Tech
Old 01-25-2007, 08:09 PM   #1
TC21's Avatar
Default Removing Rear Interior/Trunk Panels on 98 EK Hatch?
I've recently discovered a leak in my 98 Civic Hatch, and thanks to the H-T forum search, plus an $85 diagnostic check at my local Honda dealer, I found it was coming from my headlight gasket. Now instead of paying $250+ to get the gaskets replaced, I am doing it myself with some craft foam and KTV sealant.
My question is, in order to get to the 4 8mm bolts holding the headlights in place, I need to remove the plastic trim/panels in the hatch area. After quickly examining the rear, I believe the sequence goes like so:
1) remove trim covering rear speaker
2) remove trim surrounding hatch latch
3) remove trim surrounding tail lights/backseat/etc...
Is there not a better way to get to the tail lights, and if not, does anyone have any tips/suggestions on how to do this right?
Thanks.
TC21 is offline   Reply With Quote
Old 01-25-2007, 08:53 PM   #2
bpkmrtoes's Avatar
Default Re: Removing Rear Interior/Trunk Panels on 98 EK Hatch? (TC21)
really? i thought there was just some kind of plastic door thingy that revealed the nuts. well.. atleast in my legend there was... also.. im assuming you meant tail light
bpkmrtoes is offline   Reply With Quote
Old 01-25-2007, 08:57 PM   #3
HT White Ops
The way I get to my tail-lights is taking my speaker covers and speakers out, and then prying then reaching down with a socket driver and unbolting them.
Eran is offline   Reply With Quote
Old 01-25-2007, 08:58 PM   #4
bpkmrtoes's Avatar
Default Re: (Eran)
Quote:
whoa! hatches must be hard
Old 01-25-2007, 09:04 PM   #5
HT White Ops
Default Re: (bpkmrtoes)
Quote:
Well, there are plastic doors, but my hands are too big to use them the right way. I end up using them for loosening or tightening the nuts after I break them.
Old 01-26-2007, 06:46 AM   #6
TC21's Avatar
Default Re: Removing Rear Interior/Trunk Panels on 98 EK Hatch? (bpkmrtoes)
yes. there is a door, and yes, I meant tail lights. Thanks for all your help guys!
Old 01-26-2007, 07:19 AM   #7
OneSlowEK's Avatar
For the ek its a hassle just to check the lights, they have covers that go over them but that only lets you check wiring, you have to remove the whole plastic panel, then remove the covers over the light then remove the speaker grilles, and unbolt all of th ose screws then you have to remove every screw ont eh side. Slide out the whole big plastic panel now your whole side of the car is exposed. Shitty but what can you do?
OneSlowEK is offline   Reply With Quote
1992 Acura Integra Water leaks ghardman Acura Integra 13 04-01-2014 10:22 AM
Removing the vinyl interior trim around trunk latch striker ('98 hatch) dnunes Honda Civic / Del Sol (1992 - 2000) 0 05-16-2011 06:38 AM
removing climate control trim turboedsupe Honda Civic / Del Sol (1992 - 2000) 8 02-23-2009 07:58 PM
removing door mouldings on & rear tail lamps on EK hatch? kingrukus Honda Civic / Del Sol (1992 - 2000) 4 09-04-2007 07:16 PM
? about rear bumper removal eda6 Honda CRX / EF Civic (1988 - 1991) 7 02-23-2006 06:30 PM
Tags
98, back, civic, del, ek, hatch, honda, interior, lights, panel, panels, rear, remove, removing, sol, speaker, tail
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
