removing drive axle
Re: removing drive axle (EJ8 Kenobi)
THere are plenty of threads on this...
there are a few methods:
1.) Big *** Hammer Method
2.) THe craftsman 3/8" ratchet trick
3.) the honda ball joint removal tool
search and you shall find photo how-to on each...
Re: removing drive axle (Crazydave)
Well I've been beating on the lca with a 4lb sledge hammer for about an hour now and I'm not sure if it has moved at all.
I'm reading up on some other methods but if someone else has anything uncommon I'm all ears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8 Kenobi »</TD></TR><TR><TD CLASS="quote">Well I've been beating on the lca with a 4lb sledge hammer for about an hour now and I'm not sure if it has moved at all.
I'm reading up on some other methods but if someone else has anything uncommon I'm all ears.</TD></TR></TABLE>
You cant ***** it.
It' takes a Full Arms length swing with POWER pretend it's an axe and you are spiltting wood
You HAVE to HIT IT HARD
it will work.... but if it doesn't them move on to the craftsman racthet trick.
You cant ***** it.
http://www.honda-acura.net/for...17051 <---reveals methods ( craftsman one is easiest) 56k warning.
Re: (Ethan2000ls)
Yeah I gotta admit I probably did ***** it.
My dad works at Honda and when he was a team leader they assembled the front end. He told me even after setting the ball joint if they needed to make a repair. They still had to smack it with a hammer.
Re: (burnitdown)
BFH didn't work (but maybe it helped).
Ratchet method didn't work.
3ft crow bar.. FTW
Just wedged it up in there and kept pulling up then finally it broke loose!
3ft crow bar.. FTW
erikiksaz1
Suspension & Brakes
11-02-2008 05:10 PM
Ammadien
15
07-14-2006 05:00 PM
