removing dohc head??? - Honda-Tech
Old 11-23-2007, 12:32 PM   #1
94eh2's Avatar
Default removing dohc head???
im currently in the process of removing the head off of my gsr..i took off the vavle cover and even the cam rails but cant find the bolts that hold down the head..can some please post up a chart or just point out where i can find these darn bolts..thanks
94eh2 is offline   Reply With Quote
Old 11-23-2007, 12:38 PM   #2
theyre under the cams. you need to remove the camshafts completely!
prettylew is offline   Reply With Quote
Old 11-23-2007, 02:53 PM   #3
Whytey's Avatar
Default Re: (prettylew)
Quote:
yep remove the cams and you can see the bolts right under
Whytey is offline   Reply With Quote
How to remove broke bolt Raebranch Honda Civic / Del Sol (1992 - 2000) 5 01-05-2017 10:29 AM
trying to remove head, but stuck. 4g4dcruisin Honda CRX / EF Civic (1988 - 1991) 73 01-03-2013 07:49 PM
Are the 2.2L accord head bolts torque to yield? runderwo Honda Accord (1990 - 2002) 11 05-17-2006 11:48 AM
CRX Head info Formula 1 Honda CRX / EF Civic (1988 - 1991) 2 05-28-2003 12:44 PM
Head Bolt Removal Sequence AshlandSi Tech / Misc 5 10-05-2001 04:24 PM
Tags
2000, cam, cams, camshaft, crv, dohc, gsr, head, honda, remove, removing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
