OBDI or OBDII in civic ek4 96 (d16y8) ???
Old 10-19-2007, 06:22 AM
loverboy's Avatar
Default OBDI or OBDII in civic ek4 96 (d16y8) ???
Hello guys i have a question in the same subject:
I own a civic coupe 96 D16Y8 engine now my friend told me that there is a possibility that the Electrical system is OBDI and not OBDII as i fought until now !
i attached a picture of my car (http://hondaswap.com/hybrid-eg-ek-dc...53/#post880622).
How can i check which OBD r my car using ??
Its very important cause im going 2 do a b18c or b16b swap so i have to know !
Thanks.
Old 10-19-2007, 06:50 AM
slo_hatch's Avatar
Default Re: OBDI or OBDII in civic ek4 96 (d16y8) ??? (loverboy)
your car is obd-2.....all y8 are obd-2.
Old 10-19-2007, 08:09 AM
Syndacate's Avatar
Default Re: OBDI or OBDII in civic ek4 96 (slo_hatch)
All USDM 96+ Honda Civics were OBD-II.
You can verify this (in an obvious sense) 2 ways, one, there should be a big *** O2 sensor sticking out of your catalytic converter - it's quite obvious. Two, there is an OBD-II scanner access port under your dash, parallel with the gas pedal, on the left hand side (almost all the way to the wall).
I highly doubt somebody converted it to OBD-I.
They could just be running an OBD-IIa to OBD-I conversion harness with an OBD-I ECU, but that's a far cry from an "OBD-I conversion."
For confirmation on that you'll see about 8in extra of wires by the ECU.
Old 11-17-2007, 03:05 PM
loverboy's Avatar
Default Re: OBDI or OBDII in civic ek4 96 (Syndacate)
Well Guys yesterday i lifted my car i saw the first O2 sensor in the header and searched the second near the convertor but there isnt one !
So what does it says ?? my car is OBDI ?
Maby the civic 96-98 in Israel is OBDI ?
Help anyone ?
Old 11-17-2007, 05:33 PM
ejoner's Avatar
Default Re: OBDI or OBDII in civic ek4 96 (loverboy)
Pull the carpet on the passengers kick panel and look at the ecu, on its side there should be a number that starts with "P"XX . Post that number and well tell you what it is.
Old 11-23-2007, 12:43 PM
loverboy's Avatar
Default Re: OBDI or OBDII in civic ek4 96 (ejoner)
Hey !
Well I have checked the ECU the number is P2P, so my engine is OBDI or II ?
If its OBDII how can it be i have just 1 O2 sensor ??
Old 11-23-2007, 01:53 PM
prettylew's Avatar
p2p is obd2a
gmanns
12
12-09-2020 09:02 PM
xxxtierxxx
11-12-2015 08:47 AM
loso916
08-15-2014 02:37 PM
laperriere
11
05-27-2012 08:56 PM
90civicSi VTEC
Engine Management and Tuning
10-19-2008 07:17 PM
Quick Reply: OBDI or OBDII in civic ek4 96 (d16y8) ???
