Red light wont stop blinking
Hello guys. I have a 94 civic hatchback
Today after i started my car and turned it off, the red light by my turn signal wont stop blinking even when all the doors were shut. All i did yesterday was reset my ecu by unplugging the fuse and disconnecting the negative terminal on the battery. Did i do something wrong for the red light to blink non stop?
Re: Red light wont stop blinking
I just got the car, would it drain my battery if it never stopped blinking? I really think i did something wrong because it used to shut off when all the doors is closed. Also, when i would open the door i would hear a clicking sound . It sounds like a blinker but the turn signals are not even engaged.
^ i agree
op: you or someone else is going to have to go searching behind the dash and pull the remnants of the alarm out. if it's not working and assuming you don't have a key fob for it then their's no reason to leave it in there.
o.k. guys if you ever come across this problem, this is how I fixed it
Unplug negative battery terminal
Put your key onto the on position
Plug the negative battery terminal
Fixed.
Thanks guys for your opinions!!
Fixed.
Muller0317
Honda Civic (2016 - Current)
06-17-2019 12:45 PM
1970
04-13-2012 07:27 AM
