Rear Trailing Arm Bushing!
Old 07-08-2006, 10:27 PM
ecl-ricochet's Avatar
Default Rear Trailing Arm Bushing!
Ok I got the ES rear trailing arm bushings. I have the rear disc swap off of a 93 teg. Has anyone used these with this setup before? The center rod that allows the rear trailing arm to bolt to the chassis will not fit through the hole in the bushing. Has anyone here done this with the 94-01 teg arms and had the same issue? Please help!!!
Thanks a lot!
Old 07-08-2006, 10:40 PM
Unceasing Measure
Archidictus's Avatar
Default Re: Rear Trailing Arm Bushing! (ecl-ricochet)
Are you using a vice or a press to put everything together?
Old 07-08-2006, 10:41 PM
sol2hatch's Avatar
you answered your own ? silly. If you have 93 teg arms, and you bought the bushing for the 94-01 teg..... I am not sure, but the bushings are prob different.
Old 07-08-2006, 10:54 PM
BlueIntegraBoy's Avatar
Default Re: Rear Trailing Arm Bushing! (sol2hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch &raquo;</TD></TR><TR><TD CLASS="quote">you answered your own ? silly. If you have 93 teg arms, and you bought the bushing for the 94-01 teg..... I am not sure, but the bushings are prob different.</TD></TR></TABLE>
Yes, the 90-93 Integra bushing has a larger diameter than the 94-01 Integra.
Old 07-08-2006, 11:21 PM
SpydiR's Avatar
Default Re: Rear Trailing Arm Bushing! (BlueIntegraBoy)
I used 94-01 integra trailing arms, and the appropriate ES bushings. the center rod hammered into place using a rubber mallet and the supplied bushing lube
Old 07-09-2006, 08:31 PM
Default Re: Rear Trailing Arm Bushing! (SpydiR)
I am looking to get the bushings for the 90-93 integra trailing arm. Can anyone who has done this please tell me a good place to get them from. I think I want the prothane kit. Can anyone give me a hand? Thanks.
aimbot
04-22-2011 06:30 AM
IntegraBoy04
06-03-2005 07:41 AM
HamiltonRex
05-07-2004 03:55 AM
Quick Reply: Rear Trailing Arm Bushing!
