Rear subframe bolts
Old 12-11-2010, 05:23 PM
HotCheetos's Avatar
Default Rear subframe bolts
Hi I have a noob question here, I installed an ASR subframe brace, sway bar, and LCA's on my friends EJ8, the bolt that goes into the inner LCA (the one closest to the middle of the chassis I guess) and it doesn't go through all the way, it sits about a 3/4 through the nut, they're aftermarket bolts that came with the package, should I get new ones or is it just fine, and also the nut that was welded on broke lose, should we re-weld it back on? thanks for any help!
Old 12-11-2010, 06:28 PM
fv8s's Avatar
Default Re: Rear subframe bolts
Re- weld the nut and go to a local hardware store to get a longer bolt
Old 12-11-2010, 07:48 PM
Scott53092's Avatar
Longer bolt yes, suprised the bolts weren't long enough. But the threads need to be fully in contact, since the way bolts hold in are because they stretch it is important to use the threads there.
As for the nut breaking loose, I can't see why it would NEED to be welded back on. It'd be the ideal thing to do but when the bolts torqued down the nut/bolt assembly shouldn't move with the collar of the bushing at all.
Old 12-11-2010, 07:58 PM
HotCheetos's Avatar
Other than going to the hardware store, is there any other place I can get them? Thanks for the reply
Old 12-11-2010, 08:14 PM
HotCheetos's Avatar
Actually, it also has a beaks bar mounted to it, would that contribute to the fact that the bolt isn't long enough?
Old 12-11-2010, 08:24 PM
Scott53092's Avatar
That could be part of it, hmm Beaks barbracket is likw 1/4" thick? Don't remember from when I put mine on.
Old 12-11-2010, 08:30 PM
HotCheetos's Avatar
That sounds about right, the brackets on it are pretty thick, but having that said, would I still have to get a longer bolt? Sinc it's no my car, I don't want to cheap out or mess it up
Old 12-11-2010, 08:48 PM
Scott53092's Avatar
Yea I'd get some longer bolts. Make sure they are 8.8+ grade bolts and the correct thread pitch, Honda uses fine pitch, pretty sure 1.25.
Old 12-11-2010, 08:59 PM
fv8s's Avatar
Just take a trip to a hardware store?
Old 12-11-2010, 09:07 PM
HotCheetos's Avatar
Sounds good
HotCheetos's Avatar
Alright, thanks for the help!
usmarinedelta
12-27-2006 08:52 PM
Del Sol Man
72
06-21-2006 08:13 AM
ZipTieGUy
02-27-2006 06:08 PM
EGhatch33
Suspension & Brakes
24
01-02-2006 10:01 AM
MI4$DC5
19
04-02-2005 09:10 AM
Quick Reply: Rear subframe bolts
