Rear Motor Mount: 92-95 civic=94+ GSR
Old 03-25-2004, 03:39 AM
oldbeefcake's Avatar
Default Rear Motor Mount: 92-95 civic=94+ GSR
My rear motor mount is busted. I need a replacement. I did a search but only to find out that it is a pain in the *** to change that mount. I also checked prices on both models. The civic one is about $30 cheaper than the integra. Can someone tell me if they are the same? or which one to get? I've a 92 civic with a GSR swap. Thanks.
Old 03-25-2004, 04:03 AM
TurboBumblBee's Avatar
Default Re: Rear Motor Mount: 92-95 civic=94+ GSR (oldbeefcake)
yes they are a pain to change.. how are you replacing the motor mount or the motor mount bracket that bolts onto the transmission?? cause if it is the motor mount your gonnna have a tons more fun changing that than just the motor mount bracket..
and yes the civic and integra motor mounts are the same...
Old 03-25-2004, 04:12 AM
92civeg's Avatar
Default Re: Rear Motor Mount: 92-95 civic=94+ GSR (hybrid94Si)
yeah the 2 rear mounts are the same
Old 03-25-2004, 04:26 AM
Default Re: Rear Motor Mount: 92-95 civic=94+ GSR (92civeg)
If they are the same, why the huge price difference? I'm going to change the rear mount, by taking off the transmission bracket off first. I hope it is not too much pain. Thanks guys.
Old 03-25-2004, 05:04 AM
its just tight back there and not alot of space to work with.. u can do it..
Old 03-25-2004, 06:24 AM
Thanks for the heads up. I looked at it last night, I need a universal joint to fit the sockets to get to the bolts. I'm ready to bust some knockles.
Old 03-25-2004, 06:53 AM
zigs's Avatar
The mounts are the same, but if you are talking about the T bracket or L bracket they are not the same. Youll need the rear mount bracket from a 94 and up gsr or type r.
Old 03-25-2004, 07:20 AM
sammysnakes's Avatar
the mounting points are the same, but you'll need a rear mount from a 94+ integra.
Old 03-25-2004, 07:24 AM
kreush33's Avatar
Default Re: Rear Motor Mount: 92-95 civic=94+ GSR (chainsaw)
I had to pull a rear mount outta an LS for my GSR swap into my EG civic, i did it in the cold and outside with a couple tools i brought and it took me about an hour to do, its not that bad just be patient, also the L brackets are different, found that out the hard way.
Old 03-25-2004, 07:33 AM
Dan GSR's Avatar
Default Re: Rear Motor Mount: 92-95 civic=94+ GSR (kreush33)
i've got a mount for sale
check sig
Old 03-25-2004, 08:39 AM
Default Re: Rear Motor Mount: 92-95 civic=94+ GSR (Dan GSR)
I only need to replace the rear mount, not the "L" bracket. Thanks for all your inputs. I'll get the GSR rear mount just to make sure it works out.
Dan GSR:
Is the mount new or used? Also, do you have integra rear LCA? how much is the fromt LCA's and are they direct replacement for the civics?
LagunaSecaEG
23
09-15-2006 07:55 PM
boostin4door
05-23-2005 04:41 AM
RevEJ1
01-23-2004 03:13 PM
Civichatch972
12-08-2002 11:42 AM
TeamFlip02
09-12-2002 07:49 AM
Quick Reply: Rear Motor Mount: 92-95 civic=94+ GSR
