rear disc brake conversion parts list
Old 07-14-2004, 12:48 PM
gray89si's Avatar
Default rear disc brake conversion parts list
I have a 92 Civic DX, I just purchased a rear disc conversion from a 93 Integra. The parts included are rotors, calipers, hoses, trailing arms and pads. What all will be needed to sucessfully and effectively convert it from the drum system I currently have?
So far Ive found out that I need Integra E brake cables and getting SS brake lines would be worth my time, anything else?
Thanx in advance
Old 08-10-2004, 09:10 AM
* B A N N E D *
Redline96LX's Avatar
Default Re: rear disc brake conversion parts list (gray89si)
Yes get the brake cable. Im assuming you have the whole trailing arm with the hub. also, you'll need a new proportioning valve im assuming. lucky you, you can get one from a Si hatch for your year.
Old 08-10-2004, 09:12 AM
meccA's eg6's Avatar
Default Re: rear disc brake conversion parts list (Redline96LX)
How to put X Brakes on Y Car
https://honda-tech.com/zerothread?id=152884
Old 08-10-2004, 09:16 AM
Evil_Wizard's Avatar
Default Re: rear disc brake conversion parts list (meccA's eg6)
You should have got them from a 94 and up integra. I think that the 90-93 integra are the ones that bolt up to the 88-91 crx's and civic hatches. Someone let me know if this is correct or not.
Old 08-10-2004, 09:34 AM
vtec69's Avatar
Default Re: rear disc brake conversion parts list (Evil_Wizard)
i need to be doing this too
Old 08-10-2004, 01:27 PM
Default Re: rear disc brake conversion parts list (vtec69)
if you hvae a 92 dx you need
the rear trailing arm off of ANY 94-01 integra with the ebrake cable
ANY 94-01 integra brake booster, but a RS integra master cylinder(so the lines match up), and a prop valve from ANY 94-01 integra
WestSideRain
04-13-2009 08:02 AM
drewb16a
08-11-2007 11:50 PM
tna4me247
07-17-2006 08:41 PM
d15civ
10-05-2004 09:14 AM
LowFlyin'
10-20-2003 03:49 PM
Quick Reply: rear disc brake conversion parts list
