Rear car sits lower in one side then the other!
I just installed camber kit, skunk2 springs, shocks, lower arms, new rims - tires. After everything was installed, the front and rear were siting lower on one side then the other. I was told to drive it for a bit and it should even it out. Well I got home and the front was even, same as the rear. I went to work today and came back home and relized the rear was siting about 1/4'' from the tired and on the other side there is a good 3/4'' clearence. My driveway is even.
Any suggestiones?
Any suggestiones?
Re: Rear car sits lower in one side then the other!
What's the camber settings side to side? When I lessoned my negative camber in rear it lifted the rear of the car.
Also, without coilovers, the really is no way to get the car to be level.
i would just drive for some more see if it evens. although sometimes its like that, nothing you can do. if you really wanna know you should switch L/R to see if the other side is sitting lower
shouldve go with coilovers tho.
