Re-Doing A Headliner, What Adhesive to Use? - Honda-Tech
Old 11-13-2010, 01:49 PM   #1
eh vtec sc's Avatar
Default Re-Doing A Headliner, What Adhesive to Use?
My headliner is slowly getting worse and worse everyday so I decided that I should do something about it. It's a 96 civic ex. The thing is, I am unsure about which adhesive to use. I have found that these four (thanks to research and this thread) have been getting good reviews:
DAP Weldwood Spray Adhesive ( http://cgi.ebay.com/ebaymotors/DAP-W...ehicleQ5fParts )
3M 08090 Super Trim Adhesive ( http://www.handsontools.com/3M-08090...l_p_10289.html )
Loctite 37312 - Loctite Maximum Strength Headliner Adhesive ( http://www.summitracing.com/parts/LCT-37312/ )
and Automotive Headliner Adhesive Glue ( http://stockinteriors.com/headlinera...10&ModelId=233 )
Which one did you guys use? Also, did you guys strip the headliner to bare cardboard? Or did you just remove the old fabric or did you just put the new material over it?
eh vtec sc is offline   Reply With Quote
Old 11-13-2010, 02:46 PM   #2
alphalanos's Avatar
Default Re: Re-Doing A Headliner, What Adhesive to *se?
I *sed the 3M high strength 90 spray available at Home Depot, et*. J*st follow the instr**tions and it works great.
alphalanos is offline   Reply With Quote
Old 11-13-2010, 02:51 PM   #3
I *sed 3M S*per 77 for my headliner in my s13 with s*ede. It's been on there for q*ite a few months and no problems, altho*gh I'm pretty s*re S*per 90 is stronger.
omgshawn is offline   Reply With Quote
Old 11-13-2010, 05:49 PM   #4
boostedB18civic's Avatar
Default Re: Re-Doing A Headliner, What Adhesive to Use?
i work at autozone and we sell some adhesive that i have used before. worked great
boostedB18civic is offline   Reply With Quote
Old 11-13-2010, 06:19 PM   #5
I used the permatex multipurpose spray adhesive for my headliner, and it worked
miguelpr0 is offline   Reply With Quote
Old 11-13-2010, 07:04 PM   #6
fungus mungus's Avatar
Either the 3M or Automotive Headliner Glue will work fine. I use 3M Super 77 for upholstery applications and it works fine.
fm
fungus mungus is offline   Reply With Quote
Old 11-13-2010, 07:46 PM   #7
PSU
formerly DxHatchback
PSU's Avatar
PSU is offline   Reply With Quote
Old 11-13-2010, 09:34 PM   #8
Master Detailer
98civdx's Avatar
3M super 77 has never let me down.
98civdx is offline   Reply With Quote
Old 11-13-2010, 09:36 PM   #9
hueman's Avatar
Quote:
Originally Posted by DxHatchback View Post
used this. worked perfect.
be careful how much you use though... mine bled through a little
hueman is offline   Reply With Quote
Old 11-13-2010, 10:05 PM   #10
I've used 3m plenty of times with no bad experiences.
XSboosted10 is offline   Reply With Quote
Old 11-13-2010, 10:16 PM   #11
I used some permatex stuff in an orange can and it sucked. I followed the instructions and it started sagging within a couple months.
I heard not to use 3m Super 77 or such for headliners...but after hearing it's what other people used successfully...I thought about redoing mine and took it out...but it's not a priority.
NotAJDMFanBoy is offline   Reply With Quote
Old 11-13-2010, 10:24 PM   #12
hueman's Avatar
i'd get something that actually says it's for headliners
Old 11-14-2010, 12:06 AM   #13
Sure, but does anyone here buy lawn edging for their lawn? Or rubber plumbing couplers for their drains? Come on, we're building Civics, not rockets...unless we build a Civic powered rocket!
Old 11-14-2010, 01:00 AM   #14
hueman's Avatar
Quote:
i don't really understand what you're getting at... :\
loctite will definitely last through extreme weather conditions because it was designed to deal with them. will the 3m multipurpose? maybe, probably, who knows.
Old 11-14-2010, 10:32 AM   #15
I'm saying that there are plenty of things people use for things other than the intended purpose, and it's fine. It works. Loctite stuff will probably hold. Just from my knowledge, doing my own headliner and a friend using one bottle of the stuff I used and one bottle of Super 77 on her car, the Permatex stuff failed for both of us, but the 3m Super 77 held.
For something decorative, there's no reason to be all uptight. If we were talking assembly lubes or fasteners for suspension or whatever, we can get into all the little details. But for a headliner or whatever, I figure that whatever works works.
Old 11-14-2010, 11:14 AM   #16
eh vtec sc's Avatar
Great to see such a discussion on this topic.
My friend has used 3m Super 77 and the heat down here in the southwest just gets to it and makes it sag.
I asked around at a few upholstery shops and they told me that they use: DAP Weldwood HHR Contact Cement ( http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT) and spray it on with an actual spray gun. But I rather not have to buy a compressor and spray gun, that's why I am mainly looking at aerosol sprays.
At the moment, I am really leaning towards the Loctite Headliner Spray since there has been multiple good reviews on here and via google. To those that have used the Loctite Headliner Spray, how long has your headliner lasted and does your car go through variable weather changes or does it mostly stay in the garage?
So, when you guys place the new fabric on, do you take off the old foam or fabric? Or do you just lay it right on?
Old 11-14-2010, 12:27 PM   #17
hueman's Avatar
i put it on over top the old fabric.. it doesn't make it thick enough to cause any problems with reinstallation. plus, you get to keep the old, soft OEM feeling.
i'll get back to you after this winter about whether or not it holds but i have a feeling it will. be careful when you install... once it becomes tacky, that sucker will take hold
Headliner adhesive spray 3msuper90? yea or nay? EG-SIXV-TEC Paint and Body 2 11-05-2015 02:44 AM
headliner GrayH Honda Civic / Del Sol (1992 - 2000) 21 12-29-2012 02:27 AM
Door Fabric Adhesive - 3M 90 vs. General Trim novacane Acura Integra 1 10-17-2011 05:17 PM
Rear Hatch Window Replacement Ricey McRicerton Honda Civic / Del Sol (1992 - 2000) 0 04-26-2007 06:27 PM
headliner peeling away hinshu Honda Civic (2001 - 2005) 4 04-26-2007 02:01 PM
Tags
3m, 90, adhesive, adhive, apply, bad, dap, glue, headliner, httphtarchiveorgshowthreadphpp44009063, permatex, redoing, spray, vs, weldwood
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
