Radiator steaming and fan doesn't seem to be turning on
Old 02-21-2013, 09:43 PM
SlowB16's Avatar
Default Radiator steaming and fan doesn't seem to be turning on
After blowing a coolant hose yesterday, I bought a new hose, put it in, and bled the coolant system (I think I did it right). I drove the car around for about 10 minutes and ev. erything seemed fine. The temp gauge was right where it should be below the halfway point. Then when I pulled into my garage I noticed there was steam coming from under the hood. Popped the hood while the motor was still running and the steam appeared to be coming from the radiator cap. The fan never turned on.
From what I've read it seems like this could be a faulty cap, bad radiator, or air in the system. I don't think the car was overheating, but who knows if the temp gauge is working properly (prior owner swapped a gsr dash with cluster). It just seems strange the the radiator fan wouldn't turn on if the motor is hot enough to push steam from the cap.
The fan turns on when I short it, but I don't know if it'll turn on on its own. After seeing all the steam I turned he car off so I'm not sure if the fan would have kicked on.
Any thoughts on what the problem might be? Do you think the fan should have turned on?
Old 02-21-2013, 09:52 PM
dazebreak's Avatar
Default Re: Radiator steaming and fan doesn't seem to be turning on
What car do you have?
How did you bleed the air exactly?
Usually the temp gauge works unless it never moves up at all, IMO.
Steam should not be coming from the cap, you can try replacing it, or have a shop pressure test the cap.
Which hose blew (upper or lower), where did you get the new hose? Are you sure the new hose isn't collapsing?
Yes, the radiator could be plugged.
The fan should come on if the coolant is hot enough, if it doesn't the coolant temp switch could be bad, but then you would probably overheat.
In summary, I would burp the air again, then go for a new cap.
Old 02-22-2013, 05:28 AM
axis11's Avatar
Check your thermostat.
Old 02-22-2013, 05:38 AM
kyden's Avatar
replace the cap. check the cooling system for combustion gases.
Old 02-22-2013, 06:56 AM
SlowB16's Avatar
Update: drove it to work this morning and now the cap doesn't seem to be leaking, but there is steam coming from around the radiator. Now I'm wondering if a leaking radiator is causing this. The fan still didn't turn on.
Is the fan switch part of the thermostat or is it different?
The hose that blew is the one that goes from the side of the motor to the heater switch near the firewall. I got a replacement at a junkyard. It isn't leaking or collapsing.
Posted from Honda-tech.com App for Android
Old 02-22-2013, 08:07 AM
axis11's Avatar
The thermostatic fan switch plugs on the thermostat housing. The thermostatic valve is inside to regulate the flow. No flow, no heat to activate the switch.
Old 02-22-2013, 10:45 AM
98bwahhek's Avatar
check your radiator it might have a crack in it under or around radiator cap most the common place for it.
Old 02-22-2013, 05:59 PM
dazebreak's Avatar
The fan doesn't turn on much on mine, but yes, the radiator probably has a crack. Mine started steaming like that after a 15 minute freeway run, so I simply replaced it and bled it.
fuglybutruns
07-28-2015 07:50 PM
crazyhouse2011
11
03-08-2013 07:10 AM
hella_usdm
11-15-2006 07:36 AM
spock_rocker
06-06-2005 03:32 PM
hitop
01-16-2003 03:38 PM
Quick Reply: Radiator steaming and fan doesn't seem to be turning on
