RADIATOR!!! OVERHEATING!!!
Old 08-04-2008, 03:40 PM
misternguyen's Avatar
Default RADIATOR!!! OVERHEATING!!!
I just recently got a honda civic that overheats. I replaced the thermostat and the radiator cap. Now I noticed that the radiator does leak and I am losing coolant. So now I have to replace the radiator. Does anyone know if it matters what kind of radiator I replace it with? Can I use any civic radiator? Does it matter if the radiator is from a manual or automatic car? Should I purchase a used oem radiator or purchase a brand new one from schucks? Please help!
Old 08-04-2008, 03:57 PM
soclean1k_JDM's Avatar
Default Re: RADIATOR!!! OVERHEATING!!! (misternguyen)
just got done with this problem. i myself replaced the thermostat and i installed a new radiator. i went with an alluminum radiator from ebay it was about the same price as going to any autoparts store and buying the stock one this is including the shipping. i say you do the same its alot better then a stock one.
Old 08-04-2008, 04:00 PM
Default Re: RADIATOR!!! OVERHEATING!!! (soclean1k_JDM)
So any aluminum one is ok? I saw some at schucks for 100? Do you think that would be fine?
Old 08-04-2008, 04:06 PM
as long as it fits im sure you'll be fine. but the one i bought bolted right up i was even able to use my stock fan. you have to make sure the measurements are close you dont want to buy a radiator thats to tall and your hood doesnt want to close do your research first.
Old 08-04-2008, 04:08 PM
http://cgi.ebay.com/ebaymotors...ZWDVW
Old 08-04-2008, 04:10 PM
this is the one i bought
http://cgi.ebay.com/ebaymotors...96909
Old 08-04-2008, 04:15 PM
Thanks. I appreciate your help. But my car is an automatic. And I'm told that I need an oil cooler also. And that the radiators are different for automatics and manual transmissions. So I'm wondering if I should just go to honda and buy an oem one or should I spend that on an aluminum radiator?
Old 08-04-2008, 04:19 PM
im kind of new to this too but i think the oil cooler is seperate from the radiator.
not too sure im kinda new to this stuff too. yeah mine is a manual.
well theres this too someone sent it to me while i had the same problem
https://honda-tech.com/zerothread?id=2052971
Old 08-04-2008, 04:57 PM
Thanks. I really appreciate your help. I read through it and did notice that people are saying the ones at autoparts stores do work fine. I mean mines is only a d-series so I'm guessing I don't really need the aluminum one but it would be nice to have one of those. Still deciding........
Old 08-04-2008, 05:29 PM
pepsiDX20's Avatar
Radiators for automatics have lines on the bottom to allow for the oil.
Old 08-04-2008, 06:24 PM
Seagull Management
94EG8's Avatar
Default Re: (pepsiDX20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pepsiDX20 &raquo;</TD></TR><TR><TD CLASS="quote">Radiators for automatics have lines on the bottom to allow for the oil.</TD></TR></TABLE>
X2
Old 08-06-2008, 11:50 AM
Old 08-06-2008, 12:01 PM
sageuvagony's Avatar
x3
I know for a fact because my car used to be automatic and had lines running into my radiator. Now I just have the radiator holes plugged up since I have a 5-speed now.
sdinteg
06-01-2010 11:26 PM
vxtirent08
03-20-2008 10:36 AM
Dartanian
06-13-2006 09:37 PM
MachAF
08-02-2003 10:17 PM
EGh22aEG
01-09-2002 06:37 PM
Quick Reply: RADIATOR!!! OVERHEATING!!!
