question regarding thermostat
Well I am already fairly certain that I need a new thermostat. So I'm just wondering if this could also cause another issue.
When it's exceptionally cold out it takes my car FOREVER to warm up, and even then once I hit about 50mph the temp gauge goes right back down and the motor cools and stays below optimal operating temp.
Could a bad thermostat cause that?
Re: question regarding thermostat
Ok thanks. I know how easy it is, and pretty cheap, just wondering if that's my issue.
I also have no heat so I'm pretty sure that I need a new thermostat.
X2, and remember to put the little bleed hole that's on the actual T-Stat at the 12 O' Clock position when you install it.
replace it with an OEM honda piece and you will be all set
I'm having the same issue but already have replaced the T-stat with a new OEM unit as well as the radiator, fan and all hoses!! My car barely heats up to about 1/4 of the gauge and when I coast down a hill it goes back to cold!
did you have normal heat before? did your gauge stay around 1/2 way when warm?
superninja
Honda Civic (2001 - 2005)
10
12-23-2021 05:05 PM
bumthology
11
12-11-2004 11:23 AM
