Question civic cx one wire o2 sensor how can I make it to a 4 wire o2 sensor or can I even make a 4
I have a civic cx with a jdm d15b bout to be turbocharged here in januay for the new year. So on my harness I relized that I only have a 1 wire o2 sensor how can I make a 4 wire o2 sensor hookup? Thanks, Mark
what for??? are you running a P28, if so just have it chipped (for boost anyways) and do away with the o2 heater, or the o2 all together.
if you are running a p08 you only need the one wire anyways.
well I am running a p70 ecu thats what came with my swap but if I was using a p28 then when I get boost just do without it? what if I would say if I got aem wideband? would I just tune that with the ecu. sorry noobie at this. thanks
im not sure what a P70 is but i am almost certain its not USDM, which means it doesnt have an o2 heater, so the 1 wire o2 is fine. are you throwing a code???
when you go boost you are gonna have to get your ecu chipped, most people just do away with the stock narrowband o2 and use the wideband.
Technical Hero
Re: Question civic cx one wire o2 sensor how can I make it to a 4 wire o2 sensor or can I even make
You can either run it from the O2 to the shock tower harness or run the wiring directly from the O2 to the ECU
see what i am going to do when I go boost is get the aem wideband with the set up but i was just wondering if there was a way but i guess wideband is a different thing a p70 ecu is the zc ecu that came with my d15b motor from japan but it runs fine and all and yes its throwing a o2 sensor code and a 19 code as well automatic lock up code. thanks guys
thats what I thought That I have a automatic ecu but its still runs fast as **** does really good for a auto ecu lol. I think I will get a p28 pretty soon here for turbo in january.
