question about timing belt
well i am finishing up my turbo install and i am putting my timing belt back on and i did it the same way it said to do in my haynes, "put it on, turn it counterclockwise three teeth, tighten tensioner and turn clockwise two revoltions and check" i did this and yes it gets tight but once i start turning it clockwise it goes loose then tight and so on. anyone have any suggesstions?
Re: question about timing belt (Btothe3rdDegree)
umm.. you shouldnt be turning you engine backwards. MY hanyes says to turn counter clockwise and re-check tension. wierd.
Re: question about timing belt (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">umm.. you shouldnt be turning you engine backwards. MY hanyes says to turn counter clockwise and re-check tension. wierd.</TD></TR></TABLE>
.............yeah thats what i said i did, i never said i turned it backwards, you turn it counterclowise three teeth, tighten up the tensioner and rotate clockwise two revoltions, after i did that there is alot of slack in the belt the camshaft and the water pump, am i doing something wrong?
