question about rocker arms and cam gear that do not have play
So i replaced my head gasket and valve seals. And put the rocker arm assembly back on the head prior to mounting the head to the block. Now i notice no play at all in the cam gear. Did i tighten it down to far?
I did not adjust the rocker arms prior to removing or re installing..
Urgent plz help, there should be minor amount of play correct?
Re: question about rocker arms and cam gear that do not have play
play which way lol there should be none put a 12mm on the cam gear bolt and turn the cam if it turn all is still good.
KrazoMike
12-10-2011 07:15 PM
Soccerking3000
12-30-2004 07:08 AM
agent marlon
11-21-2002 11:49 AM
