Question about OBD-1 and Emissions test
I have a 99 Civic that I just swaped a 99 GSR engine into. I had the swap done at a shop. I went by there today and they said that the ECU that came with the engine would not work with my 99 Civic wiring harness because the plug will not fit in the slot on the ECU. They said I would either have to get an Si ECU and wait a couple of days forthem to get it or I could convert to OBD1 so I decided to convert to OBD1. I was wondering if my car will still pass VA emissions?
Re: Question about OBD-1 and Emissions test (dawrenn)
So if I understand you correctly, you said your car is now OBDI.
If so, no you won't pass emissions if they plug up to the OBDII port. It won't connect at all.
Re: Question about OBD-1 and Emissions test (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">So if I understand you correctly, you said your car is now OBDI.
If so, no you won't pass emissions if they plug up to the OBDII port. It won't connect at all. </TD></TR></TABLE>
Yes it is OBD1.
Where is the OBDII port?
Yes it is OBD1.
Re: Question about OBD-1 and Emissions test (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">Driver side, under the dash and to the left of the steering column - looks like a D-shape.</TD></TR></TABLE>
Where I go I dont think they plug anything under the dash.
How are OBDI cars tested? Couldnt I just tell the tester that my car is now OBDI?
Like I told you in PMs, no, you can't just tell him it's OBDI now. That's technically illegal and if the guy who does your inspections wants to keep his license, he can't pass you if your county does the OBDII port testing.
EDIT: They still put the sniffer on the OBDI cars for the time being. I hear they're going to be doing away with the OBDI emissions testing altogether before too long.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Like I told you in PMs, no, you can't just tell him it's OBDI now. That's technically illegal and if the guy who does your inspections wants to keep his license, he can't pass you if your county does the OBDII port testing.
EDIT: They still put the sniffer on the OBDI cars for the time being. I hear they're going to be doing away with the OBDI emissions testing altogether before too long. </TD></TR></TABLE>
I dont recall them using the port testing. Like I told you in the PM's The last time I got my car tested in 2004 they used the sniffer.
Also, when an OBDII to OBDI conversion is done do they switch the thing under the dash?
Re: (2lua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">why don't you go find an obd2 p72 for your motor? i think your plug wire would be obd2a.</TD></TR></TABLE>
I do have an obd2 p72 ecu but they said it wont work with my wiring harness so I would have to get an Si ECU or convert to obdII, those are the only options they gave me.
Re: (2lua)
Because he's suppose to be boosting soon and converting to OBD I anyway.
Re: (RNPoo7)
man.. im having trouble with that **** too... if ur call is a 96 or 97 above... then you must have a OBD2 in ur car... when you do a inspection.. they plug this 1 **** into ur car like wat he said... in the driver seat under the steering wheel... if you convert it to a OBD1.. HELL NO you aint passing for ****... unless you get that **** swap out left and rite everytime you get it inspect....
Re: (thangnhocngheo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thangnhocngheo »</TD></TR><TR><TD CLASS="quote">man.. im having trouble with that **** too... if ur call is a 96 or 97 above... then you must have a OBD2 in ur car... when you do a inspection.. they plug this 1 **** into ur car like wat he said... in the driver seat under the steering wheel... if you convert it to a OBD1.. HELL NO you aint passing for ****... unless you get that **** swap out left and rite everytime you get it inspect....</TD></TR></TABLE>
WHen I have had the test done they have not plugged anything up to my car.
You will not pass emissions OBD-I tests the pressure of your gas cap and also you hydrocarbons (unburned fuel) in your exhaust. At least in here in Chicago they put a long stick in your exhaust to take the hydrocarbon reading.
OBD-II is classified by the year of the vehicle and that is how the state looks up by the year of the car to know if it is OBD-I or OBD-II
Re: (Zen_Dynasty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zen_Dynasty »</TD></TR><TR><TD CLASS="quote">You will not pass emissions OBD-I tests the pressure of your gas cap and also you hydrocarbons (unburned fuel) in your exhaust. At least in here in Chicago they put a long stick in your exhaust to take the hydrocarbon reading.
OBD-II is classified by the year of the vehicle and that is how the state looks up by the year of the car to know if it is OBD-I or OBD-II</TD></TR></TABLE>
Trust me I will figure out someway to pass.
azandford
11-11-2009 11:35 AM
