question about clutch (need answers)
i put a new clutch in and i bleed the clutch but the pressure on clutch is soft... is it suppose to be like that? i bleed it a couple of times but still the same.... is there something that i didn't do right?
Re: question about clutch (db8db8db8)
its a stock clutch... will i open up the bleed,step on the clutch 3 time just to pump out air. then close it back up. then pump the clutch.. that what i did to my other swap n it work find.... so dont no whys that...
Re: question about clutch (ja20_eg)
did you do it by yourself or did you have someone step on the clutch, then after being stepped on for a couple times, did they or you hold it down there?
Re: question about clutch (ek-g6)
well on my other swap i did it by my self. but on this one my bro help me on it .....but is that what im sopose to do on bleedding a clutch....
They way i did is..
friend open up bleeder nut
i pump 5 times, then stepped on it all the way
friend quickly close bleeder nut
brought clutch pedal back up and returned to how it was...
so....pretty much on the 5th pump one person has to close the bleeder nut b4 i bring clutch pedal back up right ...
if thats right then i tried doing that 2morrow n c if it work.....so if it still the same would u know whys that like that.....
Right, on the 5th pump hold it down, while its held down have your friend quickly close the bleeder screw, then u can let your foot off.
i would say its just how the clutch kit was made, some are hard and some are soft, that would be my explanation.
aslong as your clutch engages all is good, make sure you fluid levels are up, years ago when i didnt know anything about honda, i didnt have a brake fluid in the clutch resovior, and my clutch didnt want to grab as much, it made a supercharger noise, and annoyed the hell out of me..didnt know what it was untill my friends bro in law just bled the clutch and all was good..for a day people thought i really did have a supercharger, and wanted to race, but i knew i would lose, cuz i couldnt go faster than 30 without hearing the noise. I had something that sounded like a supercharger, but definitely didnt make my car go faster..lols best of luck to you tho.
