putting ac into a 98 ek coupe gsr swap - Honda-Tech
Old 12-13-2009, 06:13 PM   #1
Default putting ac into a 98 ek coupe gsr swap
what do i need to put ac into a 98 civic ek coupe that has a gsr swap ?
GSR936 is offline   Reply With Quote
Old 12-13-2009, 06:16 PM   #2
Anon51's Avatar
Default Re: putting ac into a 98 ek coupe gsr swap
do you have your original a/c lines? no lines? evaporator? condenser? dryer? compressor?
Anon51 is offline   Reply With Quote
Old 12-13-2009, 06:18 PM   #3
car has lines but no ac compressor or condenser
Old 12-13-2009, 06:42 PM   #4
ttt
Old 12-13-2009, 07:06 PM   #5
Anon51's Avatar
do you still have the gsr a/c bracket bolted on? if not go grab a vtec delsol a/c bracket or its much cheaper counter part the crv b20 a/c bracket. and find a 96-98 d series a/c compressor. unless you wanna use a gsr a/c compressor in which case a gsr bracket and compressor and lines is what you want.
Old 12-13-2009, 07:24 PM   #6
OK i found a b20 ac bracket for 30 bucks. can i use a 97 auto d series ac comperssor?
Old 12-13-2009, 07:24 PM   #7
and condenser from a 97 auto?
Old 12-13-2009, 08:00 PM   #8
Anon51's Avatar
yea you just need teh d series compressor lines now that go from the evaporator to the compressor and condensor.
Old 12-14-2009, 07:06 AM   #9
alright just making sure the ac compressor and condensor were from a 97 civic auto were the same.
Old 12-14-2009, 07:19 AM   #10
318 Curves, 11 miles
Vindicator9000's Avatar
Quote:
Yes. Everything is D-series except the bracket which should be B20.
On mine, I retained the entire D-series A/C system with the B20 bracket. The D series compressor should bolt up to the B20 bracket and everything will line up like OEM. This is because, if you've ever seen a CRV, it uses a D-series compressor on a B-series engine.
Vindicator9000 is offline   Reply With Quote
Old 12-14-2009, 07:31 AM   #11
yes thats good. found a bracket and i got a donor 97 ek auto will all ac lines and stuff
Old 05-07-2010, 09:39 PM   #12
hey where did u find that ac bracket from a b20?
extremeEK00 is offline   Reply With Quote
Old 05-07-2010, 09:41 PM   #13
im thinking about putting a gsr swap into a 00 civic coupe and thought i needed the gsr ac bracket but read this and seen i need a b20 bracket?? is that true? how does that work?
Wtb 98 ex coupe mounts ek98gsr Want to Buy 6 02-26-2014 01:45 PM
WTB gsr or ls seats 95civc98 Want to Buy 4 05-26-2013 10:24 AM
what t bracket for gsr in ek?? HarosGSRek Honda Civic / Del Sol (1992 - 2000) 28 05-19-2009 05:32 AM
AC on a swap?? XtymourX Honda Civic / Del Sol (1992 - 2000) 6 09-19-2007 11:13 PM
wtb ek coupe 96-98 parts NJ Lip For Sale 11 02-23-2005 09:10 AM
Tags
96, 98, ac, back, bracket, civic, compressor, coupe, ek, gallery, gsr, honda, putting, series, swap, system, thread, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
