Problems with 94 Civic overheating
Old 12-24-2009, 10:11 AM
russ61nc's Avatar
Icon2 Problems with 94 Civic overheating
My 94 civic standard 4 cyl. is overheating when you drive it over about a 5 mile trip. Engine will not overheat while idling in the garage only when it is driven. When overheating occurs the heater starts blowing cold air so I am thinking it is some kind of circulation problem. Car has new radiator, water pump and thermostat. No oil in the oil or water in the exaust. When car gets hot only water lost is what goes into overflow tank. Am I right in assuming I have a circulation problem? If so why doesnt the engine overheat while idling in the garage and soesnt over heat on short trips less than 5 mile or so. Also while idling I am not getting any pressure in the radiator. Any help? Thanks Russ
Old 12-24-2009, 10:41 AM
Foobernutter's Avatar
Default Re: Problems with 94 Civic overheating
Sounds to me like its the coolant system is air locked. The rad most likely boiled over one time when it overheated. If it did, when you put coolant in did you have the heater on max defrost to make sure it circulated through heater core? I would suggest "burping" your coolant system (letting the car run with the rad cap off until you see it burp all the air out) and see if that helps the problem.
Old 12-24-2009, 12:35 PM
russ61nc's Avatar
thanks for your post. All the air was burped from the system. One thing the car does right before it starts overheating is the heater stops blowing warm air. Almost immediately the engine runs hot. Another reason I think it may be a circulation problem is the top radiator hose is hot and steam coming from the overflow and the bottom hose is cool. Again I have a new radiator, water pump and thermostat. What would cause water to stop circulating after 2 or 3 miles of driving?
russ61nc
Engine Management and Tuning
01-11-2010 11:58 AM
092eg6
06-23-2009 09:43 AM
team 15
06-15-2009 07:14 PM
usdm_3g
Classic Hondas
02-25-2009 08:43 AM
scoobyghost
03-30-2007 07:32 AM
Quick Reply: Problems with 94 Civic overheating
