Problem with map sensor on b16
Old 08-10-2005, 06:24 PM
kechup2eg6's Avatar
Default Problem with map sensor on b16
Here is the thing I purchased a jdm B16 and swapped it into my 94 civic cx. Harness is done correct and so is the swap. The motor starts but I got the check engine light on throwing codes 5(map sensor defect), 7(TPS defect), 3(map sensor defect). Now i checked to see if the sensors are bad and then noticed that the throttle body does not have a map sensor. By the way the TPS is fine. The car starts and drives but after a couple of minutes driving it the car will choke and it seems as if though the car is going to shut off. It will shut off sometimes and then it won't start until I let the car sit for a couple of minutes to cool down. I need to know if its because there is no map sensor connected and how do I adapt a map sensor to this motor if the throttle body doesn't have a spot for it? Please help me I'm a newbie to this site. Thanx
Moderator
chad's Avatar
Default Re: Problem with map sensor on b16 (kechup2eg6)
you have TPS and map plugs on wrong
Old 08-10-2005, 06:31 PM
kechup2eg6's Avatar
Default Re: Problem with map sensor on b16 (chad)
I dont have a map sensor plugged in right now. There is no spot to place it on the throttle body. I did switch the plugs though, the car then starts to stutter and when i accelerate it it revs up and turns off. How do you plug in a map sensor without having a place to put it on the throttle body and from what vehicle can i use the map sensor from?
Old 08-10-2005, 06:33 PM
Moderator
chad's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kechup2eg6 &raquo;</TD></TR><TR><TD CLASS="quote">I dont have a map sensor plugged in right now. There is no spot to place it on the throttle body. I did switch the plugs though, the car then starts to stutter and when i accelerate it it revs up and turns off. How do you plug in a map sensor without having a place to put it on the throttle body and from what vehicle can i use the map sensor from?</TD></TR></TABLE>
your old engine!
komat's Avatar
jdm b16a
have external map sensor
where did u buy your swap?
it shold of came with it
the tube running into the black thing ont he firewall is the map sensor you should be looking for
Old 08-10-2005, 07:47 PM
95DxSi-R2
Guest
Posts: n/a
get a map sensor
ThatOne02Accord
04-25-2015 12:18 PM
bodiez
10-26-2010 02:17 PM
SVOboy
03-26-2006 11:48 AM
slither
09-20-2005 10:33 AM
comptechgsr2000
05-08-2002 03:53 PM
Quick Reply: Problem with map sensor on b16
