power steering swap?
Old 12-09-2004, 12:22 PM
xcaptivasolx's Avatar
Default power steering swap?
i just bought a 94 del sol with no power steering, im wondering approximately how much it would cost to convert to power steering and if it is worth the effort. any imput would help!
Old 12-09-2004, 12:28 PM
HT Order of Merit
JDM_Ej's Avatar
Default Re: power steering swap? (xcaptivasolx)
Swap the steering rack, get a power steering pump, hose, resivoir and belt. Not that difficult, but not really worth it IMO..
keep the manual and build some muscle
Old 12-09-2004, 12:30 PM
Lee_Delso's Avatar
Alot more than you might want to spend, first you have to get a rackinpion, then power steering pump and so on and so on. Why do you want power steering, only slows you down?j/k
I think it's going to run you about $1k-2k.
Old 12-09-2004, 01:02 PM
is there any way i can just get the parts off a junked del sol (if i can find one)? i want to use this car for auto-x, not just drag.
Old 12-09-2004, 01:16 PM
Electrician
Deemeetree's Avatar
Are you sure that it's not a P/S rack with the pump, resevoir, etc...removed? Some people just loop the P/S rack so it can feel as if it has P/S with some better steering response.
If it is a manual rack, you will need to find a good, salvageable P/S rack, resevoir, pump, lines, etc...
Do some more research and check if it's a straight swap or if other steering components are needed.
Old 12-09-2004, 02:39 PM
marshun's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure that it's not a P/S rack with the pump, resevoir, etc...removed? Some people just loop the P/S rack so it can feel as if it has P/S with some better steering response.
Do some more research and check if it's a straight swap or if other steering components are needed.</TD></TR></TABLE>
umm no, it doesnt feel like power steering with better response. it feels like no power steering with a quicker turning radius
not only will you have to get a power steering rack and pinion, you'll need to put on the new tie rod ends and get the thing realigned (thats if you cant do it yourself). changing that thing with regular hand tools sucks too.
everyone says 1-2k. but you can take your time and piece it together for prolly around 500 bucks. i pieced one together a while back for like 50 bucks. friend of a friend got rear ended and parted out the car. so it really depends on how you find your parts
Old 12-09-2004, 02:45 PM
Electrician
Deemeetree's Avatar
Default Re: (marshun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marshun &raquo;</TD></TR><TR><TD CLASS="quote">
There's a different feel from a looped P/S rack to a non-PS rack. What I'm trying to say.
Old 12-09-2004, 02:49 PM
sleepyEK's Avatar
actually, correct me if i'm wrong, but i believe the m/s racks have a longer ratio lock to lock than the p/s.
Old 12-10-2004, 09:18 AM
marshun's Avatar
Default Re: (sleepyEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyEK &raquo;</TD></TR><TR><TD CLASS="quote">actually, correct me if i'm wrong, but i believe the m/s racks have a longer ratio lock to lock than the p/s. </TD></TR></TABLE>
exactly. thats the only reason a looped and a non ps rack feel a tad different.
i've done both just to try it out.
Javao007
08-08-2012 06:07 PM
d15DEELSOL
08-10-2009 06:49 PM
goldenmac
24
09-16-2006 01:11 PM
DevilSolSi
14
11-08-2002 11:26 PM
HondaCutie90
02-25-2002 03:58 PM
Quick Reply: power steering swap?
