Possible causes for the SRS light to turn on? - Honda-Tech
Old 03-02-2004, 03:58 PM   #1
Default Possible causes for the SRS light to turn on?
My SRS light wont go out! I havent messed with anything related to the system, so its not user error. It came on a month ago, but went out shortly after. Now its on again, but its been on for a few weeks without going out. I disconnected the battery for 15 mins but that didnt help. Could there be a possible short in the wiring, or are there parts that actually go bad in this system?
BTW: 1997 Honda Civic EX
Rydaddy is offline   Reply With Quote
Old 03-02-2004, 04:43 PM   #2
teamunleash's Avatar
Default Re: Possible causes for the SRS light to turn on? (Rydaddy)
Try this link hope this helps...
http://honda-tech.com/zerothread?id=264288
teamunleash is offline   Reply With Quote
Old 03-02-2004, 09:53 PM   #3
boostedbluebeast's Avatar
reseting ecu doesn't clear srs codes you'll probably have to take it to the dealership to get the code read by a technician and have it cleared... it shouldn't cost you anything if you take it to a honda or acura dealer...
boostedbluebeast is offline   Reply With Quote
DIY SRS-Bypass Plug dem0nk1d Honda Civic / Del Sol (1992 - 2000) 32 09-29-2011 03:58 PM
SRS light on - aftermarket seats - questions about dealership... kefka Acura RSX DC5 & Honda Civic EP3 7 11-10-2009 02:21 PM
SRS Module Replacement jstel Honda Accord (1990 - 2002) 4 09-21-2009 12:53 PM
95 Accord EX V6 SRS light stevescivic Honda Accord (1990 - 2002) 1 05-15-2009 11:35 PM
SRS and ABS Codes Solster Honda Civic / Del Sol (1992 - 2000) 8 01-28-2009 08:42 AM
Tags
2002, 2003, bad, battery, causing, civic, civics, del, error, honda, light, on, sol, srs, triggers, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
