popping noise from front end 98 civic - Honda-Tech
Closed Thread
Old 01-31-2012, 09:26 AM   #1
Default popping noise from front end 98 civic
NEW TO HONDA-TECH...... so every once and a while i will get this loud popping creaking sound when going over speed bumps and sharp turns or combination in school parking lot(main time i hear it). I am not sure whether it is a dry ball joint (needs grease) or the inner tie rod . the noise is from passenger side. i ordered new ball joint boots for the camber kit(newer) to see if it fixes the problem. but how can i test to pinpoint the noise. i have shaken wheel sideways up down all around and no movement. which is why i am leaning toward dry ball joint (boot is torn). but any help is appreciated Thanks.
hawksftball2007 is offline
Old 01-31-2012, 09:47 AM   #2
cdn ek9's Avatar
Default Re: popping noise from front end 98 civic
Check your lower and upper balljoint. Mine made that noise when the lower balljoint worn.
cdn ek9 is offline
Old 02-02-2012, 02:52 PM   #3
I checked and lower ball joint was fine, but wat i figured out was when i replaced upper ball joint boot. the coilover bushing where it attaches to car, had a popping noise so i tightened the bolt and nut up, and no more popping noise. Thanks
Old 02-02-2012, 03:17 PM   #4
pityocamptes's Avatar
Quote:
So what did you tighten? My vehicle does not pop, but it does make this irritating creaking noise when going over bumps. I was starting to think its the rubber mounts that go on either side of the springs. I know the rear makes the same noise. I have checked the ball joints and they are fine. Thanks!
pityocamptes is offline
Old 02-03-2012, 03:03 PM   #5
the bolt that attaches the camber kit to the car. it was loose. so i put a bit of locktite on it and tightened it down....creaking sounds like from springs. but try and tighten the bolt and nut down for the front upper control arm.
Old 05-05-2015, 11:50 AM   #6
Revival from the dead to pass along info.
My brother's 97 civic was making a loud pop mostly when he would back out of driveways with the wheel cut right. Turned out to be a loose bolt on the upper control arm where it bolts to the body. He was able to replicate the noise at a stand still and I could see and hear it. Problem solved.
ali954 is offline
Old 05-05-2015, 09:24 PM   #7
^Good info.
I'll lock this old thread now.
Former User is offline
Closed Thread
popping thok thok noise upon acceleration and braking Pnoyej6 Acura Integra 11 07-10-2006 07:28 PM
lower ball joints DelSolMarine Honda Civic / Del Sol (1992 - 2000) 5 03-15-2006 09:47 PM
Do the ingalls front camber kits come with new upper ball joints? untitled Honda CRX / EF Civic (1988 - 1991) 0 04-04-2004 01:01 AM
CV joint/boot problem Simple Honda Civic / Del Sol (1992 - 2000) 5 02-01-2004 03:46 PM
Ball joint help drewlee Honda Civic / Del Sol (1992 - 2000) 2 05-18-2003 05:10 PM
Tags
00, 03, 2002, 98, accord, civic, crx, end, front, honda, noise, noisy, popping, rod, sound, tie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
