Piston/Rod combo - advice/opinions
Old 02-08-2012, 04:19 AM
Slacker93eg's Avatar
Default Piston/Rod combo - advice/opinions
I finally got my tax return and it's time to buy the pistons and rods for my LSVtec Turbo setup (see link in signature). I'm going for 400-500whp with lower boost.
Let me know what you guys think of this deal, and are these rods going to be okay
http://www.ebay.com/itm/Wiseco-Forge...item5ae13802ec
Old 02-08-2012, 06:21 AM
Default Re: Piston/Rod combo - advice/opinions
Bump - waiting to press buy now button! Let me know
Old 02-08-2012, 06:24 AM
EK9
Dc4LsTeG's Avatar
Have you checked the sponsors on here? I think they might be a little cheaper
Old 02-08-2012, 06:30 AM
I haven't checked, I will have to look into that. 785$ seems like it's a fairly good price for pistons and rods, but I'll look into the sponsors now. Thanks, any other input?
Old 02-08-2012, 06:32 AM
Shaunathan's Avatar
Eagle and Wiseco are what the majority go with, and is what i'll be using when i swap. i say push yes but i believe their are sponors on here that sell them cheaper like stated above.
Old 02-08-2012, 06:33 AM
EK9
Dc4LsTeG's Avatar
Here's the same company just on here for cheaper
https://honda-tech.com/forums/showth...ston+rod+combo
Old 02-08-2012, 06:42 AM
Very nice, thanks alot dude
Old 02-08-2012, 10:23 AM
Just ordered Wiseco pistons and Manley rods from RSP - thanks for the tip! Great deal!
Old 02-08-2012, 11:20 AM
NotAJDMFanBoy's Avatar
Wiseco, JE, and some companies use different alloys from SRP. It's stronger but has a higher coefficient of expansion. It's fine, especially considering it's only an 81mm piston, but SRP (cheaper line of JE) use the same alloy as cast OEM pistons so they expand less, meaning a tighter p2w clearance, and should last a little longer. Not sure if they're good for that much power though.
Old 02-08-2012, 12:34 PM
EK9
Dc4LsTeG's Avatar
Old 02-09-2012, 06:15 AM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
I always heard CP pistons were good and one of the only pistons which clearances are always within a thousandth of an inch, I want to say.
Old 02-12-2012, 09:52 AM
D16siT's Avatar
does anyone else use fr rods and y.c.p pistons they are cheaper than the other brands and just as good
Old 02-12-2012, 09:55 AM
The Grumpiest
grumblemarc's Avatar
What are FR rods? Have you done ANY research? Did you check any of the links that have been posted? Define "cheaper". What is your budget?
ryan_1014
03-30-2009 05:50 AM
civic_saints1
07-07-2007 05:23 PM
forcedaccord95
04-30-2005 10:07 PM
boost fed ls
01-29-2005 04:20 AM
integra-modder
07-17-2002 10:19 PM
Quick Reply: Piston/Rod combo - advice/opinions
