What is this hard black plastic I found in my transmission?
Old 05-03-2012, 01:06 PM
Ser1N's Avatar
Default What is this hard black plastic I found in my transmission?
So I opened the transmission housing and I found 2 pieces of plastic, pretty hard plastic at that.
Are there plastic pieces in the transmission that it broke off from?
Or could someone have dropped it from the top?
Old 05-03-2012, 01:27 PM
Former User's Avatar
Default Re: What is this hard black plastic I found in my transmission?
Please post a smaller sized picture.
Old 05-03-2012, 01:36 PM
RuckinEK
Guest
Posts: n/a
Wow, have no idea.
Old 05-03-2012, 01:45 PM
Fixed
Old 05-03-2012, 02:07 PM
Ser1N's Avatar
Originally Posted by RonJ@HT
Fixed
thanks, I need to remember to change the res on my phone when taking pics for here. always show up huge.
Old 05-03-2012, 02:29 PM
Seagull Management
94EG8's Avatar
Broken pieces of bearing cage most likely. That's the only plastic that's supposed to be in there other than the speedo gear.
Old 05-03-2012, 02:37 PM
Ser1N's Avatar
I am starting to have this feeling that the person who had it before me broke the speedo gear bracket and it fell in. I just picked this sucker up and decided to inspect the inside, good thing I did.
I dont see any bearing issues.
Old 05-03-2012, 05:38 PM
Ser1N's Avatar
Your 100% right on. broken bearing cage! I went ahead and took a diagram and checked over them and found a broken one. I hope the broken bearing didnt mess anything else up.
Thanks!
Old 05-05-2012, 06:11 PM
Seagull Management
94EG8's Avatar
Thanks!
Np. They normally wont cause any other damage, although I have seen one ruined mainshaft due to a bad input shaft bearing. Dissamble the transmission and clean everything up really well. Make sure you dissamble the gear stacks so you can properly clean the input and countershafts. broken pieces of bearing cage like to plug up the oiling holes. replace the bearing and the seal under it. Also make sure you stake the clutch housing countershaft bearing with a punch to keep it from walking out.
The Quaff
12-19-2013 05:43 PM
stevenDAtegra
Transmission & Drivetrain
12-06-2009 11:58 AM
ludedeg
11-03-2006 08:33 PM
HT Chaplain
05-03-2005 03:26 PM
Quick Reply: What is this hard black plastic I found in my transmission?
