Pics of completed vtec OBD1 P72 ECU wiring
Old 04-11-2011, 04:19 PM
MeCrObS's Avatar
Default Pics of completed vtec OBD1 P72 ECU wiring
If anybody could find(i could not) a pic of a OBD1 P72 ECU wired for vtec.
I would like a reference picture to help me out. i know where to wire it and what to wire but not really sure how it should look. also pictures of the sensors the wires run to would be great.
Old 04-11-2011, 05:16 PM
Technical Hero
HondaPartsHero's Avatar
Default Re: Pics of completed vtec OBD1 P72 ECU wiring
Old 04-11-2011, 07:21 PM
MeCrObS's Avatar
Holy Shizz! thanks man. By far the best pic/diagram i've seen. this should be a sticky or something.
Old 04-11-2011, 07:41 PM
MeCrObS's Avatar
^Hondapartshero
I went to check out your website and found a Honda Acura OBD1 VTEC conversion swap harness.
Is this all the wires and everything i need to wire vtec from my ECU to my motor/sensors?
Old 04-11-2011, 07:49 PM
MeCrObS's Avatar
one other thing hondapartshero. if im gonna have an aftermarket intake manifold, do i just not hook up the IAB? or do i need to chip/tune my ECU?
Old 04-11-2011, 07:51 PM
phoxking's Avatar
IAB COLOR(A17)* isn't that the charcoal/vapor canister?
Old 04-12-2011, 01:24 AM
Technical Hero
No its the IAB solenoid and vacuum chamber
if you are using an aftermarket intake manifold you won't need the IAB wiring and you can just use the OBD1 VTEC subharness I sell, plus its cheaper. It includes all the wiring and connectors needed to basically plug and play. No need to chip the ECU as it won't throw a check engine light for the missing IAB's.
Old 04-12-2011, 09:26 AM
MeCrObS's Avatar
Ok thanks hondapartshero. I will be buying that when I get off work today. Thanks for all the help
Old 04-12-2011, 10:12 AM
jdmhondas4life's Avatar
awesome diagrams !!!!!! really easy to understand and will help a lot of people!!!!
Old 04-12-2011, 11:31 AM
MeCrObS's Avatar
Yeah that is by far the best pic/diagram I've ever seen
Old 12-14-2012, 04:56 AM
MrDoza's Avatar
Best diagram I've seen. Just what I needed. Thanks man!
Old 08-05-2014, 08:14 AM
gabrielsousa's Avatar
o2 sensor ground on obd1 pinouts is D22
can i connect the o2 sensor ground on ( A23 or A26 or B2 ) ?
Old 08-05-2014, 01:50 PM
Fish Twig
tony_2018's Avatar
Why would you deviate from what honda put in place?
Old 08-05-2014, 03:00 PM
The Grumpiest
grumblemarc's Avatar
Why?
Old 12-29-2016, 09:12 AM
pitti's Avatar
Icon5 Re: Pics of completed vtec OBD1 P72 ECU wiring
Originally Posted by HondaPartsHero
missing brown dot body ground
Old 12-29-2016, 09:54 AM
Technical Hero
The body ground goes to a ground on the body or engine, although you could tap into an ECU ground it's easier to just use a good know body ground location
civickiller
09-24-2009 08:18 PM
TMC_EF
01-24-2009 05:12 AM
jdmEF8racer
10-18-2006 08:56 PM
civicbeater97
07-21-2003 08:36 PM
Project92Hatch
04-17-2003 10:52 AM
Quick Reply: Pics of completed vtec OBD1 P72 ECU wiring
