Pic of diagram for rear suspension 92-95 coupe - Honda-Tech
Old 10-11-2005, 07:48 AM   #1
DaWhiteCoupe's Avatar
Default Pic of diagram for rear suspension 92-95 coupe
Like the title says, I need a diagram of the rear suspension to a 93 civic coupe for the part number to the, I think the 3 bolts in the LCA.
Snapped of while putting on springs.
Thanx
DaWhiteCoupe is offline   Reply With Quote
Old 10-11-2005, 07:59 AM   #2
Default Re: Pic of diagram for rear suspension 92-95 coupe (00G s R_93Coupe R)
ttt
Old 10-11-2005, 08:14 AM   #3
dpetro1's Avatar
cant post the pic right now but check out http://www.hondaautomotivepart...R+ARM
looks like part #29 for the two outside bolts
then go here http://www.hondaautomotivepart...ORBER to the shock absorber category for the middle bolt
looks like part #15 for the middle bolt
dpetro1 is offline   Reply With Quote
Old 10-11-2005, 08:17 AM   #4
Default Re: Pic of diagram for rear suspension 92-95 coupe (dpetro1)
thanx for the help
Old 10-11-2005, 08:25 AM   #5
Relic1's Avatar
in case you need them... honda part nubmers.
rear lower shock bolt - (10x84) - 90172-SK7-A01
outer lower arm - (10x80) - 90173-SR3-003
inner lower arm - (10x80) - 90173-SR3-003
Relic1 is offline   Reply With Quote
progress coilovers cs2 94_ls Suspension & Brakes 5 02-21-2011 04:50 AM
Wiring diagram for brake lights and turn signnals (both hatch and coupe) INVALID Honda Civic / Del Sol (1992 - 2000) 1 01-15-2006 02:05 PM
need rear suspension diagram for 95 accord aclau21 Honda Accord (1990 - 2002) 1 12-01-2005 04:40 PM
Does anybody know these part numbers? c_buz Acura Integra 8 11-14-2005 02:08 PM
Helms diagram for front suspension White Lightnin Honda Civic / Del Sol (1992 - 2000) 1 08-19-2003 01:36 PM
Tags
2002, 90, 92, 9295, 93, civic, components, coupe, diagrahm, diagram, honda, rear, shock, suspension, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
