Pedal almost to floor
!994 Del Sol. My daughter has been driving this car and there has recently been a noise in the back brakes. They have been working fine except for the noise.
I pull the wheels and started to pull the calipers. The pistons didn't want to compress, but I was able to get them off. On both, the inner pad was worn twice what the outer pad was. I tried again to compress the piston, but it wouldn't move. Bought new rotors, calipers and pads. Bled them per the book, but the pedal goes almost to the floor before getting firm. Even then, it's not spongy.
Bled/flushed them again with a vacuum pump pumping almost a quart of fluid through the system. Still, the pedal goes almost to the floor before getting firm. Car stops fine and the pedal is not spongy at all.
It seems to me that something is wrong and I don't want my daughter driving it like this. Any suggestions?
Cool Cool Island Breezes. BOY-EE
Re: Pedal almost to floor
The rear caliper pistons don't compress back in. They screw back in. Did you get new caliper slide brackets? If not, your old slide pins are probably stuck. The fact that one pad wore out faster than the other kinda points to slide pins being stuck. Remove them, clean then with a wire wheel, clean the bore with a bottle brush (steel bristles). Use brake cleaner to flush the bores out and clean the pins themselves. Use high temp brake grease. Reassemble. You can buy brake hardware packs if your pins are really bad. You can also buy new brackets altogether.
Check the fronts as well.
Rockauto.com is a better place for brake parts (better quality pads/rotors/parts than most part stores) for way less $$.
BTW, I checked the front and the slides are good.
I use honda high temp urea grease on my cars. Lucas makes a decent high temp grease for disk brake applications too.
Maybe seals in the master cylinder are gone. Cheap fix if you buy a re-man from autozone. Im running on three years with the one I got from them. Only like $25...
When I did the brakes I changed everything. Master cylinder, calipers, AND Hoses.
Unless you know the maintenance history you are relying on 20 year old parts to stop a car.
I was giving the car to my son for his birthday so it got a lot of new parts.
I got my flex lines from Rock auto. Very well made and fit perfectly.
After the 'gravity bleed', I bled again using 20' of clear hose so it would return the fluid back to the reservoir. Bled RR, LF, LR, RF. Pumped three times and cracked the bleeder, closing it before the pedal hit the floor (I had help). Did this about 10 times to each caliper after I saw no bubbles. Cycled through each caliper in order a second time.
Pedal is better but still not where I remember it. It does get hard - not spongy at all. Guess i'll drive it for a while to make sure everything it good.
Thanks for all the suggestions.
CivicDXdude
13
06-24-2012 12:54 PM
soulconfiguration
01-01-2008 03:09 AM
integrakilla
12
05-05-2004 05:08 AM
