PCV Valve replacement
I ask everyone to begin laffin....now..I sell cars I don't work on them, but wanna learn some things.
I'm bout to replace my pcv valve and just wanna make sure i got this right..
1.remove valve cover
2.do i just pull out the pcv and put the new one in? I just picked the valve from the Honda dealership, should it be a pastic L shape?
3.replace valve cover gasket
Am I right? any hints/tips??
Ok, you can quit laffin now.
Re: PCV Valve replacement
What year and engine?
You don't need to remove the valve cover to replace the PCV valve. It's generally plugged into a rubber grommet in the oil breather chamber. Follow the hose from the intake manifold to locate it.
Ok, turns out im a dumbass...i was just overcomplicating things...I need to wait till i get some hosing tomorrow. Turns out that whomever had the car before me cut the line coming from pcv valve to the manifold then just plugged the end with a 10mm tag bolt. I had to replace the dipstick b/c anytime I ran it and the turbo got anywhere near 5lbs of boost it would blow it out and spray oil. The new dipstick stays in, but I know it doesn't fix the problem, which is the excess blow back. The catch can I'm orderin will take care of that, but I did figure out what was wrong after looking ALOT closer. I do appreciate the help tho!!!
mclasser
03-26-2013 04:06 AM
