PCT or P73
Old 04-29-2009, 10:42 AM
99fbpem1's Avatar
Icon2 PCT or P73
I have a stock b16 and I am planning on putting ITR/CTR valve springs and ITR/CTR cams in sometime this summer. I was told I could swap out my P2T for either the PCT or P73 with no problem (granted they are obd2b).
My question will I see any difference between these two ECU's?
The more info the better. Thanks
Old 04-29-2009, 11:23 AM
redlinetuning's Avatar
Default Re: PCT or P73
You'll have the better timing/fuel maps for the CTR cams if you use the PCT. However, only the CTR intake cam is different. The exhaust cams are the same.
Old 04-29-2009, 11:39 AM
99fbpem1's Avatar
So,
If I get a CTR intake cam I should get the PCT
If I get an ITR intake cam I should get the P73
Thanks
Old 04-30-2009, 09:38 AM
99fbpem1's Avatar
Can anybody else shed some light on this? Are there any other problems to running a PCT or P73 in place of my P2T
Just want to make sure before I spend $150 on an ECU
I know there aren't any PCT USDM ECU's but there are USDM P73's. Is there any problem with running a JDM ECU on a USDM engine? Whether it's a P73 or PCT
Thanks
Old 04-30-2009, 10:10 AM
95egb18c3's Avatar
my advice?
on the cheap, get a obd1 Vtec ECU chipped out, get the obd2-obd1 jumper harness, and then get the car tuned on crome.
Or...on the expensive side, get an AEM EMS and get it tunned. You'll be much happier than running a stock ECU.
Old 05-19-2009, 03:47 PM
2001B18C1GS-R's Avatar
Thanks
so is there a big deal running a jdm p73 over a us p73 whats the difference will it throw a check engine in a obd2b car
Old 05-19-2009, 05:36 PM
Relic1's Avatar
CTR/ITR exhaust cams are the same.
CTR/ITR Intake cam 99-01 spec are the same.
ITR intake cam 96-98 spec is different.
(3* not really a huge deal in the grand scheme of things)
Put simply
you have a B16, the PCT ECU is for a B16.
If you had a B18 I'd say go with the P73.
The P73 will be more fuel than you'll want.
Also, keep in mind that in OBD2b flavors, only the USDM P73 exists, but it has an immobilizer. (coded ignition key, PITA)
All JDM ECUs are OBD2a (PCT and P73)
So you're going to need a conversion harness, why not drop to OBD1 and tune it...
Difference between JDM and USDM P73s, the JDM ECUs are basically OBD1 inside, and will not communicate with OBD2 scan tools.
They are also tuned to run slightly higher compression ratio, and on slightly different fuel.
Ra GS-R
08-10-2007 03:50 PM
projekZERO
08-29-2005 04:06 PM
ALLmoTorB18CrX
06-27-2004 09:55 AM
type_r_556
06-22-2004 09:36 PM
Combustion Contraption
06-11-2003 10:58 PM
Quick Reply: PCT or P73
