Part number for starter cut relay (PIC included)?
Old 08-09-2010, 09:17 AM
omgwtfbbq's Avatar
Default Part number for starter cut relay (PIC included)?
Included in the pic below, boxed in red is the Starter Cut Relay. I've taken this printout to Autozone and Oreillys, along w/ the relay itself. None of them could figure out a matching part, mostly because their system does not include a starter cut relay (or so they told me). I am guessing that I may need to purchase it from the OEM
Any help in determining an OEM part number for this relay, or a number I can take to an automotive parts store would be greatly appreciated. Thank you in advance.
BTW, I have a 1994 Honda Civic EX, manual trans...bone stock.
omgwtfbbq is offline
Old 08-09-2010, 09:22 AM
Hybrid96EK's Avatar
Default Re: Part Identification (PIC included)
If I am not mistaken, that is part of the factory alarm system. Does this car have a factory alarm on it? There are things listed in that diagram for ALL makes of cars. See the daytime running light relay? Thats canadian, but its still listed. Just because its there in the picture doesn't mean your car is equipped with that item. Whats the reason you are seeking this relay anyways?
Hybrid96EK is offline
Old 08-09-2010, 09:30 AM
omgwtfbbq's Avatar
Because my car won't start. I've replaced everything except for this (starter, ignition, clutch switch), and it still wont start. I searched my manual and am assuming that this is the last piece to the puzzle. Yes, my car has an alarm, no I don't know if it is factory or not. I've never used the alarm, and the person who sold it to me never used it, so I am not sure whether it even works. I've tested the relay and it is bad, and since I can turn the starter by wiring 12v+ straight to the starter, then it must be this.
Unless you have other suggestions, I don't see what else to change.
Old 08-09-2010, 09:31 AM
Former User's Avatar
It's rare for the starter cut relay to fail. Have you ruled out the safety switch at the top of the clutch pedal and the rubber stopper that presses on the switch?
Former User is offline
Old 08-09-2010, 09:32 AM
omgwtfbbq's Avatar
Also, if you say this is part of the factory alarm system, and i have it on my car, wouldn't that mean that my car came w/ a factory alarm? I'm no sherlock homes, but i would assume it does.
Old 08-09-2010, 09:33 AM
omgwtfbbq's Avatar
yes i did. Any with my luck, since it is rare, it probably happened to me.
Old 08-09-2010, 09:35 AM
Is the rubber stopper intact (see red arrow).
Does the relay test bad?
Old 08-09-2010, 09:39 AM
The starter cut relay is the same as the A/C compressor clutch or condenser fan relay, so you can try swapping them.
Old 08-09-2010, 09:42 AM
omgwtfbbq's Avatar
Yes, the rubber is intact.
I tested the relay and it was bad.
Old 08-09-2010, 09:43 AM
omgwtfbbq's Avatar
U sure? the numbers on them arent the same. I'll try it though, dont see where it could go wrong. Ive tried everything else.
Old 08-09-2010, 09:46 AM
Sorry, I missed that you had posted this already. Try swapping the cut relay with one of the A/C relays. Maybe the auto parts store sells the A/C relays, which should be the same as the cut relay.
Old 08-09-2010, 10:42 AM
Hybrid96EK's Avatar
This just seems like a smart *** response. Maybe I took it wrong...
You didn't post in your original post if you had the factory alarm so I asked. If that pisses you off then either don't post on a public forum or include more information. Quite often you will find things on the car that are put there in normal production and simply not used until the rest of the components are added.
I don't see how you haven't thought to find a matching relay on the car (such as the A/C one listed above) to swap in its place. This would rule out the relay as your problem or identify your issue. I guess you aren't sherlock holmes as you said earlier.
Old 08-09-2010, 11:36 AM
omgwtfbbq's Avatar
didnt mean it in a smart *** manner. This relay is labeled differently than the others. Didn't want to swap them out and then **** something else up. Anyway, Im gonna try it out and i'll let you guys know. Appreciate all the help guys.
Old 08-09-2010, 12:38 PM
Hybrid96EK's Avatar
Ah. Alright then, no harm no foul. Let us know.
Old 08-13-2010, 11:48 AM
Oh look, I can change this
deschlong's Avatar
Default Re: Part number for starter cut relay (PIC included)?
You can swap it with your horn relay, too -- real easy because that horn relay is right there attached to the right side of the fuse box.
deschlong is offline
Old 09-20-2010, 05:12 PM
purestreetracer's Avatar
im having the same problem with my 90 prelude. i was also suspecting the starter cut relay. my starter is good..im getting power to the fuse box when i turn the key..and keep hearing a click when i turn the key. im not sure where my starter relay is at but im gona trace the wiring and see where. i do believe its the relay cuz it isnt my ignition switch if im getting power when i turn my key and goes back to 0 volts when i stop turning the key.
purestreetracer is offline
Old 09-20-2010, 05:24 PM
k i found out what mine is..it is the clutch pedal switch A. It is not a relay! i push on the button on the switch A and it starts easy. i think the part that makes contact isnt making contact with that switch cuz the rubber insert corroded and fell out. Honda puts a rubber insert in a hole that is suppsed to make contact with that switch..mine being an older car probably wore out...idk why honda even put an insert instead of just making the whole think flat and metal. well found my prob hope it helps you guys out.
Old 11-05-2016, 02:01 PM
whltng's Avatar
Icon4 Re: Part Identification (PIC included)
And this fixed itself or the op pushed off a cliff. Come on guys post when you get it fixed... Geezz
whltng is offline
Wazup
02-10-2009 02:14 PM
8520
Audio / Security / Video
15
09-08-2008 12:14 AM
2.3lcivic
10-01-2007 09:34 AM
Mario_D
01-09-2007 01:18 PM
Quick Reply: Part number for starter cut relay (PIC included)?
