Painting Window molding - Honda-Tech
Old 09-27-2011, 08:48 PM   #1
Rover2cool's Avatar
Default Painting Window molding
Any painted window molding? any got some pictures? Do i sand it down or just spray paint it? Would this be okay?
Rover2cool is offline   Reply With Quote
Old 09-27-2011, 09:07 PM   #2
SpeedoKing's Avatar
Default Re: Painting Window molding
I have been thinking about doing this for some time now as well. I take it you are talking about the black molding around the bottom of the window? I would sand/scrape off all of the paint, or what ever it is, it is kinda rubbery. Then spray it, maybe try using a rubber spray paint. I think it is worth a try especially considering replacing it with a new part that has fresh paint is $90 per side.
SpeedoKing is offline   Reply With Quote
Old 09-27-2011, 09:09 PM   #3
AztecEGhatch's Avatar
Ive been wanting to do this for a while, took off my door panel but could not figure out how to remove the trim. Any advice on removal anyone?
AztecEGhatch is offline   Reply With Quote
Old 09-27-2011, 09:52 PM   #4
If you want, tape off the area with masking tape and newspaper, and scrape it first, sand it with some red scotch bright or say 600 or higher sand paper and then spray paint it.
motegicivic is offline   Reply With Quote
Old 09-27-2011, 09:53 PM   #5
to take off the molding on the bottom of the window.. you first have to remove the 3 screws on the door that hold the molding on the side.. then you basically just slide the molding toward the back and it comes off.
royce93EG is offline   Reply With Quote
Old 09-27-2011, 09:55 PM   #6
Quote:
Thank you! also, side note, how do i get in on this teal hatch club in your siggy? hehe
Old 09-27-2011, 10:44 PM   #7
usdmed9's Avatar
I've been meaning to do this as well. Somewhere around here I saw a write up on painting this. If you still need pictures that thread should be pretty easy to find
usdmed9 is offline   Reply With Quote
Old 09-28-2011, 07:42 AM   #8
TOP91's Avatar
I just did this on my 97 civic on the driver side and havent gotten around to the pass. side yet so maby if it stops raining i can take a before after picture and post it.
I didnt use anything special just a can of Kyrlon Fusion. I used satin black because thats what i painted my steel rims with.
I wound window down, Took off doorcard, Took off mirror, got on the outside of door and grabbed the trim and took it off by pulling in a rolling motion towards myself and it popped right off without breaking any plastic yellow clips. Everything will come off without much force and should snap right back in.
What i had problems with is when I pulled the Molding off the back drivers side window to paint. It pulled right off I painted it. But when i put it back on it WOULD not slide back over the window in one particular spot. I could get the whole thing looking perfect but this one spot just wouldnt push in no matter what. I had to take a razor blade and shave down the inside of the molding slightly over and over untill it slid back in and then perfect!
TOP91 is offline   Reply With Quote
Old 09-28-2011, 10:10 AM   #9
I found this write up on painting the trim/moulding. Although they did not remove it http://honda-tech.com/showthread.php...iy+window+trim
Old 09-28-2011, 10:31 AM   #10
Kohen's Avatar
i need to do this as well.. it will look much better painted haha.
Kohen is offline   Reply With Quote
Old 09-28-2011, 10:09 PM   #11
usdmed9's Avatar
Quote:
That's the one I was talking about
Upper Molding Replacement - 90 CRX Mike91204 Honda CRX / EF Civic (1988 - 1991) 4 07-19-2016 06:03 PM
Window trim removal for paint question integra supersilverdc2 Paint and Body 0 04-09-2015 01:00 PM
Finally Painting The Integra Oreo-TeCk Acura Integra 5 03-06-2014 05:40 PM
Paint on Window Molding/trim... Hunters teg12 Paint and Body 3 05-20-2012 07:21 AM
Things i would like to buy. CunninLynguist For Sale 5 12-10-2002 10:30 PM
Tags
1997, acura, civic, del, honda, howtoremovecivicbottomwindowtrim, moulding, paint, painting, rear, remove, repainting, rsx, sol, trim, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
