P28 ECU Manual or Automatic
Old 07-15-2006, 07:21 AM
GiMpInThaCiv's Avatar
Default P28 ECU Manual or Automatic
How do you tell if a p28 ecu is from a manual or automatic?
Old 07-15-2006, 07:23 AM
nocturnaldragon's Avatar
Default Re: P28 ECU Manual or Automatic (GiMpInThaCiv)
You should read the ecu thread stickied to the top of the forum. Its in there, but regardless heres a pic of how there different internally.
Old 07-15-2006, 07:54 AM
philosofy1's Avatar
Default Re: P28 ECU Manual or Automatic (nocturnaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">You should read the ecu thread stickied to the top of the forum. Its in there, but regardless heres a pic of how there different internally.
you can't tell just by looking at the picture.
"take a look at the following jumpers in the lower right hand corners of the ECU,
RP17 and RP18 values:
Auto to Manual:
remove RP17 and RP18
replace RP18 with a jumper wire"
this is from the ecu thread, this is how your able to tell from auto - manual, and make the change.
Old 07-15-2006, 01:15 PM
Thanks for the info guys
Old 07-15-2006, 04:27 PM
what does the 10th jumper look like on a manual ecu? R13? is there a jumper on it? Its cut off in that picture.
Modified by GiMpInThaCiv at 5:43 PM 7/15/2006
donaldmejr
08-13-2007 07:29 PM
Serdar
02-14-2006 10:52 AM
lv6l
10
12-10-2005 10:09 PM
skunk2unerz
11-16-2002 07:37 AM
Quick Reply: P28 ECU Manual or Automatic
