P1399 and P0135 Codes....
Old 10-16-2006, 02:49 PM
StreetRacinThug's Avatar
Default P1399 and P0135 Codes....
Car-1997 Honda Civic EX
Motor-97 USDM B18C1 (Used to be Turbo)
Mods-I/H/E and AEM Tru Time Cam Gears
Ignition-STI Spark Wires, NGK Plugs, OEM Rotor and Cap.(Cap has some damage due to friend)
ECU- OBD2a P72
Well heres the thing basically ever since I have had the swap the car has been spitting smoke through the valve cover intake hole were we a lot of people but the breathers on. It smells a lot like fuel. People say its my injectors, injector seals, too much pressure build up on the head, burning oil, bad mixture of air and fuel. I really dont know what it is but the car isnt as fast as its supposed to be. Its not running as strong as my previous GSR swap but I do feel and hear VTEC. Also the spark plugs wear out fairly quickly. I fixed all the misfires. And finally always there is some dark liquid build up around the intake manifold ports. Idle is from 1k-2.5k. Its not steady.
Now my codes are P0135 after my car caught a trash bag in the middle of the street and caught fire. Im not sure if this code is for the o2 sensor before or after the cat I rewired the wires from the cat to the cabin behind the center console.
Second code is P1399 which I have no clue. The code has been on for about 3 weeks. I hear like a farting or ticking or rattling sound when the gas is applied for the past 2 weeks. When I got this sound I had just gone through a pretty deep puddle since it was raining. I wasnt shifting hard all day or anything so I dont think it was a money shift. Ive read from bad valves to a basic misfire.
Please help guys im trying to make this car run perfect.
Old 10-16-2006, 03:05 PM
excivicboy96's Avatar
Default Re: P1399 and P0135 Codes.... (StreetRacinThug)
well the PO135 is for the front Heated Oxygen sensor. I cant find the code for you second code are you sure its the right one.
Old 10-18-2006, 10:09 AM
100% positive it is the right code. I believe its a manufacturer code. Now people are saying Im losing compression and I have bent atleast 1 or 2 valves.
Old 10-18-2006, 10:58 AM
Anyone else
Old 10-21-2006, 03:05 PM
Up
Old 05-24-2010, 01:02 PM
derjac's Avatar
Old post, I know, but I came across it when I was looking for a fix of the codes I just ran. P1399 for my 1997 Honda civic ex is a blocked EGR passage. Hope that helps if you haven't figured it out yet.
Old 05-24-2010, 01:39 PM
Former User's Avatar
P1399 indicates multiple misfires. The damaged cap is the place to start.
P0135 - Is 7.5A dash fuse 15 blown?
Old 08-09-2010, 03:06 PM
freydaddy's Avatar
after a search, i came right to this thread.
I have the same 2 codes.
P1399=manufacturer controlled ignition system or misfire
P0135=Bank 1/ Sensor 1 O2 sensor Heater Circuit Malfunction
I just removed the breather chamber, cleaned it, and replaced the PCV valve.
I cleaned the intake and TB while it was off.
So i am thinking Dizzy? or fuel injector?
Also i noticed only 1 O2 sensor at the header. Attached to 4 feet of wire.
is there suposed to be another(2000 Civic EX)? OBD2 (a or b?) after the cat?
edit
i just found out that #4 and #2 are not getting spark...runs on 2 cyliders only...impressive
TD 73U dizzy may be the culprit.
I also noticed there is a wire running from the drivers side connector (tee'd off another wire) and goes to one of the dizzy wires
Any gurus have a clue for a fix on my new purchase?thanks in advance.
Old 08-09-2010, 05:06 PM
freydaddy's Avatar
bump to refresh
Old 08-10-2010, 11:49 AM
freydaddy's Avatar
ttt
Old 08-10-2010, 03:42 PM
freydaddy's Avatar
i was wrong about not getting spark, i took off the 2 and 4 plug wire and snapped in some plugs i got sitting around. they are both sparking, so i am wondering about the fuel injectors.
how many things can this code be related to? bent valves?
help please.
Old 08-10-2010, 04:31 PM
freydaddy's Avatar
would a bad o2 sensor cause the other code?
could just be the o2 sensor...i only have 1.
Old 10-08-2010, 03:51 PM
InnerCityNinja's Avatar
^^^ Did you ever get this fixed?
Ericrallwm
Honda Civic (2001 - 2005)
04-12-2015 03:59 AM
SmaTTeRLegion
15
09-02-2013 11:28 AM
dalet3
08-01-2010 09:43 PM
fast_honda
07-12-2006 05:54 PM
travis
06-15-2002 02:12 PM
Quick Reply: P1399 and P0135 Codes....
